how to caculate the Galerkin projection
Old   March 15, 2006, 08:46
Default how to caculate the Galerkin projection
ztdep
hell0:
I don not how to caculate the Galerkin projection.
( laplace(T), phi )
Where phi is the basis, and i want to project the laplace(T) onto the phi, but 1), what is the meaning of ( ) , and i have the value of T only at discrete points, then how to caculate it.
regards!
Old   March 15, 2006, 09:34
Default Re: how to caculate the Galerkin projection
al
Let us assume a(x) and b(x) two functions in an interval [0,1]. Then (a,b)=integral a(x) b(x) dx
means the inner product, (dot product), between the functions a and b. This can be considered as a projection of a() into b() and the other way around.
This is much more simple, for the case of simple vectors, e.g. a=[1 0 1] and b=[1 0 0] (a,b) = |a| |b| cos( angle (a,b) )
Equivalent, (laplace(T),phi) means that you want to determine the projection of laplace(T) into phi.
Why do you have only discrete points? Are you using a Galerkin spectral method?
Any way, if you have only T at some points, e.g. T[i] , then you can compute approximately laplace(T) at the same points, laplace(T)[i]. Then you can approximate the inner product as
(laplace(T),phi)= laplace(T)[1] phi[1] Deltax + laplace(T)[2] phi[2] Deltax+ ...
where Deltax is the space between the points.
Old   March 15, 2006, 21:36
ztdep
Hi,Wed:
thank you for your feedback!
would you like to give me your email address, i have some question!
regards!
Old   March 15, 2006, 23:52
Mike
See here
http://community.livejournal.com/res....html#comments
Mike
Old   March 16, 2006, 01:03
ztdep
Mike:
what have you give me! i can not get any information from it? then how to use it
Old   March 16, 2006, 01:49
Mike
My name is "Michail" and I'm Russian
in Russian it means "BEAR"
http://community.livejournal.com/ru_preved/
Bear is our natianal HERO
Galerkin projection sara2115 Main CFD Forum 0 June 5, 2011 11:57
projection method for helical pipe(3D) ehsan_am86 Main CFD Forum 0 August 14, 2010 22:30
[blockMesh] BlockMeshmergePatchPairs hjasak OpenFOAM Meshing & Mesh Conversion 11 August 15, 2008 08:36
free surface flow and projection methods sylvain Main CFD Forum 2 April 26, 2002 10:45
A Second-Order Projection Method for Incompressibl Ivan Main CFD Forum 5 April 29, 2001 08:27
