Problem with Joule-Heating simulation in a high aspect-ratio system
Old   November 28, 2012, 16:27
Default Problem with Joule-Heating simulation in a high aspect-ratio system
farshadsm is on a distinguished road
I have a problem with a code which I have written to simulate Joule-Heating through a 3D cubic system made of silver. When the aspect ratio between l_x/l_y (l_x and l_y are the length of the system in x and y direction) is less than 100, I get good results from the code independent of the number of grid points generated in the system. However, when the l_x/l_y is larger than 100, the temperature distribution predicted by the model shows deviations from a true symmetric distribution for even 30000 grid points which are not really large. What could be the problem? I have used a resistive networks to solve electrical and heat conduction equations.
I appreciate for any help.
Farshad
farshadsm is offline   Reply With Quote
Old   November 29, 2012, 04:28
Rami Ben-Zvi
Rami is on a distinguished road
Hi Farshad,
  • Are you using a CFD package, and if so - which?
  • With a large aspect ratio, did you also use high aspect ration cells? If so - it can explain the difficultiy you are experiencing.
  • You did not mention the Lz / Lx ratio. Please specify.
Rami
Rami is offline   Reply With Quote
Old   November 29, 2012, 07:57
Originally Posted by Rami View Post
Hi Farshad,
Rami
Hi Rami,
Thanks for your answer. I am using our in-house code which is basically a Finite-Difference code. I think you are right. Because I try to shrink the aspect ratio of the grids in the high-aspect ratio case and now it's giving me the right answer. Lz/Lx = 1.
Thanks again,
Farshad
Old   November 30, 2012, 13:00
Originally Posted by farshadsm View Post
Hi Rami,
Thanks again,
Farshad
Rami,
Is there any mathematical rule or basis for choosing the correct value for the time step as well as grid boxes for large geometrical aspect ratio?
Farshad
Old   December 4, 2012, 04:09
Rami Ben-Zvi
The time step should be selected by considering stability and accuracy. The stability depends on the scheme you use, and - if your boundary conditions, initial conditions and sources are extremely time- or space- dependent (e.g., have discontinuities of high derivatives) - they may also influence stability. Accuracy is usually improved by smaller time-steps. The aspect ratio is implicitly dealt with when considering the characteristic length for stability.
[Commercial meshers] [fluent3DMeshToFoam] High aspect ratio cells found (mesh from ICEM) alquimista OpenFOAM Meshing & Mesh Conversion 10 January 29, 2013 16:28
use of high aspect ratio cells near walls Usman FLUENT 0 January 23, 2008 08:16
Problem on high density ratio in Level Set method Kai Yan Main CFD Forum 10 December 25, 2007 07:12
mesh for a high aspect ratio geometry matthias CFX 3 October 20, 2006 03:55
high aspect ratio elements Olivier CFX 5 April 3, 2003 07:55
