singularity distribution about panel method
Old   November 27, 2012, 21:59
Unhappy singularity distribution about panel method
Derek2580
rogerliu is on a distinguished road
In panel method, is it possible to use a source distribution (uniformly distributed on each panel but different strength at every panel) and linearly varying strength vortex? if possible, how to calculate the influence coefficients? are there any codes available?
Thank you very much!!
rogerliu is offline   Reply With Quote
Old   November 28, 2012, 11:14
Thumbs up
RZA
Engr.RZA is on a distinguished road
Start with the uniform source distribution and calculate the influence coefficient then move to your actual problem.
You can get the detailed theory and mathematical modeling in the Low Speed Aerodynamics By Joseph Katz & Allen Plotkin
Engr.RZA is offline   Reply With Quote
Old   February 5, 2013, 13:30
Default Comparison of lift coefficient of naca 0012 for different aspect ratio rectang wings
Zeeshan
Zichan Riyadh is on a distinguished road
Dear All,
I have written a low order 3d panel method code for lifting surfaces. I have calculated the lift coefficients for different wing configurations. I want to compare my results. Can anyone suggest how can I compare and from where.
Thanks
Zichan Riyadh is offline   Reply With Quote
panel method
How to plot streamline with panel method? Fluman Main CFD Forum 2 June 2, 2014 06:51
Problem with implementing unsteady Kutta condition-Hess and Smith Panel method samarthgk.nitk Main CFD Forum 0 June 25, 2012 03:36
Panel method meshing programs Charles Main CFD Forum 3 March 24, 2007 14:54
panel method for separated case nik Main CFD Forum 0 August 22, 2001 07:58
ref of a paper for panel method Anonymous Main CFD Forum 3 January 31, 2001 12:16
