Class Project
Old   March 9, 2006, 12:10
Default Class Project
Tiger
Dear Forum,
I am currently a graduate student in computational math and we are required to do a CFD project? The length of time of this project is only a semester. Does anybody have any ideas for projects? Please let me know, thank you.
-Tiger
Old   March 9, 2006, 16:40
Default Re: Class Project
Earth Global Security 777
Earth climatology
Old   March 9, 2006, 22:12
TITAN Algorithms, Staff
How about a phase-field simulation of dendritic growth with coupled bouyancy induced natural convection. Refer to the Ivanstov theory for self similarity. Model CS as a paraboloid of revolution. Seems like a neat problem.
regards
DSS
Old   March 13, 2006, 11:54
Jim
Depends on what they want you to learn from the project. If they want you to learn about the physics, then do something involving turbulence models. If they want you to learn about numerical methods, do something about compressible flows and the variations you get with different descritisation methods. You could do a nice supersonic jet, and run it with lots of different solution schemes, and compare the apparent numerical diffusion/Gibbs errors etc. Or, if you want to be really clever, you could have a moving reference frame mesh with some sort of closed loop control (like on an aircraft). That would be GREAT! Or you could just prove that numerical diffusion is worse when the flow is diagonal to grid lines. Or just write about the conjugate gradiant method.
Old   March 13, 2006, 12:03
Jim
...or maybe you could come up with an UBER higher order scheme, or write a paper explaining to us poor engineering types what things like monotonicity and TVD actually mean (something to do with boundedness apparently). Or maybe you could derive the Navier-Stokes equations from scratch. I knew a maths guy who did that once. You maths types like those sorts of pointless exercises don't you. How about writing a little CFD solver that uses the finite element method instead of the finite volume, and have it working with solid mechanics, then I wouldn't have to use CFX anymore to do my aeroelastics. Or maybe you could invent a new sort of cell, that has all the flexibility of tets, but with the low diffusion of hexas. Or write a surface tension algorithm that actually works. Or debug PHOENICS so that actually works. Or you could write about Fourier analysis of residual plots. And then you can explain it to me.
Old   March 13, 2006, 16:58
Vijesh Joshi
try out with some problems where you should not waste much of the time in mesh generation but try to play more with pre and solver and post.
thobois class engineTopoChangerMesh error Peter_600 OpenFOAM 4 August 2, 2014 10:52
Extend Project Release 1.6-ext hjasak OpenFOAM Announcements from Other Sources 33 July 14, 2011 19:54
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
class project topic pradeep Main CFD Forum 1 October 12, 2006 02:30
CFD project idea John Cleveland Main CFD Forum 4 March 8, 2005 13:55
