some problem about caculation of quadrature
Old   March 8, 2006, 04:10
Default some problem about caculation of quadrature
ztdep
Hell0:
ervery one !
i want to compute the integeral of some variable over whole domain, the intergral need a high resolution gauss quadrature method, but i only have the varible value on my two dimensional grid points, the gauss quadrature need the value at the gauss quadrature points, then how should i know it.
it is a two diemsional rectangle domain. regards
Old   March 8, 2006, 11:04
Default Re: some problem about caculation of quadrature
al
maybe you should use a spectral method.
Old   March 8, 2006, 11:10
ztdep
can spectral method caculate the integral
Old   March 8, 2006, 15:25
al
you wrote: "..I want to compute the integeral of some variable over whole domain, the intergral need a high resolution gauss quadrature method, but i only have the varible value on my two dimensional grid points, the gauss quadrature need the value at the gauss quadrature points, then how should i know it. "
I am assuming that your solution/ or your points are given in terms of a low order method, i.e. FDM or FVM. Your problem is that you want to use a high order quadrature for computing the integral (I dont know why). Of course, your quadrature point does not coincide with your FD/FV points. So, my suggestion was if you require high accuracy you should consider a high order method for example galerkin spectral method, or variations depending on your problem for computing your solution.
So, by the way why you want to use a gauss quadrature ? if you have your points uniform distributed you can use a rectangular integration rule or equilavents.
Old   March 8, 2006, 18:58
ztdep
thank you very much! i am doing a Galerkin projection onto the POD eigenmode, the projection is a integral, and it is nesessary to evaluate it with a high resolution scheme! the pod eigenmode was obtained from the FVM solutions.
regards
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 11 September 4, 2024 05:28
conduction problem venkataramana OpenFOAM 3 December 1, 2013 08:30
UDF compiling problem Wouter Fluent UDF and Scheme Programming 6 June 6, 2012 05:43
natural convection problem for a CHT problem Se-Hee CFX 2 June 10, 2007 07:29
Adiabatic and Rotating wall (Convection problem) ParodDav CFX 5 April 29, 2007 20:13
