November 18, 2012, 10:51 |
Particle behaviour in cfd
Red Admiral
Rep Power: 14 |
I have some questions concerning turbulence models and simulating the behaviour of solid particles in a fluid stream.
My fluid stream has a free stream velocity of 1 m/s, in a pipe of DN26 and a few areas where my velocity drops down to about 0,2 m/s. The speed drops are not gradually. There are also zones where recirculation is possible. My particles have a Ø with a range from 10 to 200 µm. I'm not sure what turbulence model is usefull to simulating the particle behaviour as accurate as possible. As a start I used a fixed turbulence velocity model. Since it's usefull for preliminary results. The other available models are:
Which model would you suggest? Is the fixed turbulence viscocity not usefull in this situation, not even for preliminary results? Also I've calculated the wall distance to my viscous layer: 0,01 mm (pipe is DN26). Now I wonder if it's necessary to simulate the friction with near wall meshing or a wall function in this kind of model. I've used slip wall as a start. Because my fluid is water and the viscocity is quite low. Is the behaviour of the viscous - and buffer layer on the turbulent layer to important to ignore? I'm quite new to modeling turbulent flow but eager to learn. If someone has other good suggestions or tips. I'll be glad to read them |
STAR-Works : Mainstream CAD with CFD | CD adapco Group Marketing | Siemens | 0 | February 13, 2002 13:23 |
ASME CFD Symposium, Atlanta, July 2001 | Chris R. Kleijn | Main CFD Forum | 0 | September 13, 2000 05:48 |
ASME CFD Symposium, Atlanta, July 2001 | Chris R. Kleijn | Main CFD Forum | 0 | August 21, 2000 05:49 |
Which is better to develop in-house CFD code or to buy a available CFD package. | Tareq Al-shaalan | Main CFD Forum | 10 | June 13, 1999 00:27 |
public CFD Code development | Heinz Wilkening | Main CFD Forum | 38 | March 5, 1999 12:44 |
