Flow over a cylinder
Old   March 7, 2006, 23:36
Default Flow over a cylinder
Anna
I'm doing a research about the flow over a circular cylinder. I have a few things that I don't understand. My questions are:
1) What is the difference between horizontal cylinder, vertical cylinder, circular cylinder and vertical/horizontal circular cylinder?
2) I found that in some paper, they used the cartesian coordinate in the equation for this problem. Some other paper used cylindrical polar coordinate in the equation. Is it we can use any coordinate for this problem or there is a certain condition in choosing the coordinate?
Can somebody help me? -Anna-
Old   March 8, 2006, 04:13
Default Re: Flow over a cylinder
Kasyap
Dear Anna...
well...i don't know the precise answer for ur first question...but as far as the 2nd quest. considered i think the selection of cord sys. depends on ur convenience...for a cylinder like problem it is obvious that analysis wud be simplified if u use a cylindrical sys
best regards Kasyap
Old   March 8, 2006, 04:42
ramp
Hi !!
[1]. When the flow is approaching over a cylinder placed horizontal in the flow stream (side view will show a cross section of cylinder) is horizontal flow While in case of the vertical cylinder (side view will show a length of cylinder) is vertical cylinder flow
The cylinder may be of two type: one is the circular cylinder which has a circular cross section (say radius r) and other is square cylinder which has the square cross section (say side of square r).
The horizontal and vertical cylinder is nothing but cylinder (circular or square) place in flow streams.
[2]. One can solve the problem in any coordinate systems.
You can also refer the following two books to get the feel of the things about circular cylinder:
1. Zdravkovich, M.M. (1997). Flow around circular cylinder Volume 1, Fundamentals. Oxford University Press, New York, USA.
2. Zdravkovich, M.M. (2003). Flow around circular cylinder Volume 2, Applications. Oxford University Press, New York, USA.
Best regards, Ramp
Old   March 8, 2006, 05:39
Anna
Dear Kasyap and Ramp,
Many thanks for the information given.
Best regards, Anna
Old   March 8, 2006, 07:24
changkiang
well, for the 1st, maybe it depends on whether we take the gravity into account, or there is no difference.
Old   March 8, 2006, 08:49
ramp
Hi !!
The placement of the cylinder and the direction of flow is two different things. The placement of cylinder (horizontal or vertical ) does not account for the gravity.
The flow directions can be horizontal, upward and downward flow. The gravity comes into picture when the flow is vertical (i.e., upward or downward).
Best regards.... Ram
Old   March 10, 2006, 01:06
worasit
Hi! Anna
I think for the 1st question, the major difference to be considered between vertical and horizontal cylinder is 'end effect' not 'gravity'. For short vertical cylinder, end effect can reduces several percent of drag coefficient. Generally, when you consider horizontal cylinder, end effect will be neglected.
For 2nd question, you can use any coordinates system to solve your problem.
Best regards
Old   March 10, 2006, 04:09
ramp
Hi !!
The horizontal and vertical cylinders are completely different situations..... The drag will also not be same for the both schematics.
I think, there will be significant end effects in case of the finite length cylinder (vertical or horizontal) only, not for the infinite length cylinder.
Best regards... ramp
Old   March 24, 2006, 04:18
Anna
Hello again,
I've read some papers about unsteady boundary layer flow past an impulsively started circular cylinder. Based on my understanding,
1) the problem begin with no backflow, then exist a separation point at a finite time, followed by flow reversal
2)for a steady boundary layer flow, there is a singularity at the separation point
3) for unsteady problem, the question whether there exist a singularity is still couldn't be answered.
4) finite-time singularities do not develop in solutions to the Navier-Stokes equations.
5) the flow reversal first occur at the rear stagnation point.
I've some questions about this topic too:
How can we explain the application of this topic in a real situation especially for the small time solution (no flow reversal) for all points along the cylinder surface?
The solution at the stagnation point is important to be find (I think so), what about the solution for other points along the cylinder surface, is it as important as at the stagnation point?
Regards, Anna
Old   March 24, 2006, 15:32
ramp
Hi !!
I think your understandings are correct. If you have not, then have a look on the following two papers...
[1] Williamson, C.H.K. (1996) Three-dimensional wake transition, Journal of Fluid Mechanics 328 pp. 345-407
[2]Williamson, C.H.K. (1996) Vortex dynamics in the cylinder wake, Annual Review of Fluid Mechanics 28 pp. 477-539
These will give you detailed info about stationary circular cylinder.
Do you mean the applications of these studies (flow without separation behind the cylinder?). They can be applicable in high viscous flow problems such as melts, polymer solutions etc.
I think solution is important over the complete surface of the cylinder to analyse the detailed characteristics because one can not estimate the local and macroscopic properties like Drag and heat transfer coefficients, etc. without getting the solution over the cylinder surface.
Its not possible to solve the full N-S equation analytically and so the limiting cases such as boundary layer approximation (solution upto the point of separation) and creeping flow (no separation) solution are available in the literature.
best regards.... Ramp
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 12:47
1 Was FSI for a flow over a cylinder vmlxb6 CFX 17 May 16, 2011 03:29
Moving a Cylinder in cross flow after solving Dynamics equations of motion maruthamuthu_venkatraman OpenFOAM 1 November 19, 2009 14:55
Flow around a sphere and a circular cylinder Francis Main CFD Forum 0 September 29, 2008 06:16
Flow over a flat plate & Flow over a cylinder cfdxue Main CFD Forum 0 November 27, 2007 00:26
