velocity field
Old   March 5, 2006, 11:11
Default velocity field
Faiz Ahmed
Hi All,
I have a problem with velocity field for a dispersion case. When I impose velocity in some direction, after some time I find that the flow direction has changed. I have applied Pressure boundary condition at the other boundaries. I have even relaxed the Pressure BC's, But it is not working out. Also I have found that if I change relaxtion factors, again, I encouter similar problem.
Hoping for a quick response.
Thanks alot.
Saving velocity field and reading it back for another case pranab_jha FLUENT 2 September 1, 2023 02:44
accessing another velocity field in bc daviderzen OpenFOAM 0 April 20, 2011 07:24
velocity of massless particles and velocity of flow field in same coordinate payam_IUST FLUENT 0 October 19, 2009 00:24
Reconstruction of velocity and pressure field Jianglan Main CFD Forum 0 October 6, 2008 01:04
Pressure from velocity field Svante Hellzén Main CFD Forum 5 November 30, 1999 19:20
