March 3, 2006, 19:53 |
pressure correction at thita=0
Hi! I am writing a code for a cylindrical grid in 3D.Can you suggest me an article that describes the boundary conditions at thita=0 or 360 degrees in the SIMPLE algorithm.Or can you describe me in detail? I need this detail,because I have implemented and something must be going wrong,but I can't figure out what. Thank you in advance!
March 5, 2006, 21:39 |
Re: pressure correction at thita=0
What I would like to know is at the boundary conditions for the momentum equations, for the circumferential direction (thita) I set for thita=0 degrees,that is I=2, SU=SU+AE*U(1,J,K) and then AE=0.0 ,and so on for the other 2 momentum equations?
March 6, 2006, 18:58 |
Isn't there anyone that has written a code for 3D cylindrical flow using pressure correction method to give me some advice?
Strcture of pressure correction equation in PISO stable over time ? | sebi | Main CFD Forum | 1 | October 26, 2010 23:19 |
changing the coefficients of pressure correction | Noel | Phoenics | 1 | April 7, 2009 09:54 |
Pressure correction scheme in axissymmetric model | Adam Wu | Main CFD Forum | 0 | September 30, 2005 12:45 |
residual in the pressure correction | George | Main CFD Forum | 2 | July 28, 2005 05:43 |
a problem about pressure correction method | tommewang | Main CFD Forum | 2 | May 15, 2003 22:18 |
