March 4, 2006, 00:50 |
Re: Ever played paintball? HELP HELP HELP HELP!!
#21 |
Sorry, I needed to paste all the previous postings into one notepad document. One more time I am sorry, when I asked about sharp edges I did not mean knife like edges, in fluid mechanics when a fluid is turned through a 90 deg( you are talking about T holes in the air passage ) this is a real problem for me ( the actual flow area is not the same as the true mechanical area ) you see the air reservoir pressure is 270 psi but the pressure at the chamber is just 55 psi Why? Losses
Are you living in the east, I live in upstate NY, Where can I have a good look at this device near by? It would make things easier to explain using common sense rather than using technical language? OK you do not have access to a cad system that can produce a file I can read, could you produce a free hand sketch of the air passage and upload it to that web site (Try to be as exact as possible ) Cheers |
March 4, 2006, 01:25 |
#22 |
rochester
i'll post my response to the other stuff u said when i get home. |
TimeVaryingMappedFixedValue | irishdave | OpenFOAM Running, Solving & CFD | 32 | June 16, 2021 07:55 |
[blockMesh] StitchMesh on two patches | anita | OpenFOAM Meshing & Mesh Conversion | 31 | April 4, 2013 12:51 |
Oodles and more | r2d2 | OpenFOAM Running, Solving & CFD | 10 | September 23, 2007 02:54 |
OpenFOAM and Salome | fred | OpenFOAM Pre-Processing | 6 | September 25, 2006 21:36 |
Easy problem waiting online | joywe | OpenFOAM Installation | 8 | May 30, 2005 13:19 |
