Gasification modelling using non-premixed combustion |
November 8, 2012, 05:08 |
Nurul
Rep Power: 14 |
Hello everybody,
I'm simulating gasification using Non-Premixed Combustion and DPM. In this forum, I want to ask about my problem. First, the char conversion 24% (is very low). Do you have any suggestion to get higher conversion by using non-premixed combustion? I've been simulated this by laminar finite rate model in same test condition (T=367K; P=1atm;Size particle = 25 micrometer; loading factor = 0.933 kg coal/kg gas) and char conversion 99.99%. Second, can we use wet combustion in Non-Premixed Combustion? Then, am I right if I think that liquid in wet combustion means water added (not moisture content of coal)? If I want to inject steam to gasifier, what should I set? Hopefully your answer. Thanks. |
dpm, non premixed combustion, wet combustion |
Modelling of premixed combustion in a burner rig | ThomasS | FLUENT | 12 | September 7, 2018 14:07 |
Modelling Combustion in Porous Zone | tanjinjack | FLUENT | 2 | September 26, 2016 05:10 |
Nonpremixed Combustion Model for Coal Gasification | C.Y.Ler | FLUENT | 2 | April 29, 2014 09:51 |
Partially Premixed Combustion - Direct Fired Boiler | oknus | FLUENT | 0 | April 10, 2012 11:52 |
Non-adiabatic Premixed combustion through scriptin | Mahesh | FLUENT | 0 | March 31, 2007 09:19 |
