Problem in applying Gamma-Retheta transition model |
Mehdi Babamehdi
Rep Power: 15 ![]() |
dear friends;
hi, I face the problem in applying Gamma-Retheta transition model in my code. in fact, it started to converge, but after 2000 iteration, its results are not correct. as you can see figures, Cf is not correct and it should match with analytical turbulent Cf on flat plate after transition to turbulent regime. I think the problem stems from the velocity profile, as you can see in second figure, velocity profile near flat plate doesn't have turbulent velocity profile shape. in fact, it is similar to Laminar profile and even the shape of the flow that face with adverse pressure gradient. I guess problem comes from the intermittency equation. next figure shows intermittency in where above velocity profile was taken. and amazingly, as you can see in K profile in next figure, code does not work and it has very strange shape. I don't know why this happens. I have tried to find the reason of the problem, but I can not find any thing. the initial and boundary conditions for this case are : Reynolds Number= 752536.0 Rmu (mut/mu)= 6 Tui in inlet= 3.1% , Tui in leading edge= 1.99% |
Mehdi Babamehdi
I should mentioned that I used Malan et al. and menter (2009) empirical correlation formula for Flength and critical momentum thickness Re and non of them provide good results.
Mehdi Babamehdi
any idea which can fix the problem?
turn off wall functions in Transition SST model? | johnp | FLUENT | 11 | May 26, 2020 13:57 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Problem in Buoyancy Model? | dhrubo | CFX | 3 | June 5, 2010 05:32 |
modelling transition with v2f turbulence model | pablo | FLUENT | 0 | August 7, 2006 15:44 |
problem with MFR model for multiphase mixing tanks | Srinivas | Main CFD Forum | 1 | November 7, 2005 14:16 |
