Question about shifting turbulence model from K-Omega to SSG Reynolds stress
Old   November 3, 2012, 15:03
Question Question about shifting turbulence model from K-Omega to SSG Reynolds stress
Anna Tian's Avatar
Meimei Wang
Anna Tian is on a distinguished road
Hi
I'm shifting the turbulence modeling of my simulation from K-Omega to SSG Reynolds stress. The grid independence study result works well for my K-Omega simulation.
May I ask do I need to do the grid independence study again? (Only because I change my turbulence model)
Thank you very much.
Best regards,
Meimei
Anna Tian is offline   Reply With Quote
Old   January 20, 2013, 12:30
Question
Anna Tian's Avatar
Meimei Wang
Originally Posted by Anna Tian View Post
Hi
Could someone answer me this question? Thanks!
Best regards,
Meimei
Old   January 20, 2013, 13:36
cdegroot's Avatar
Chris DeGroot
cdegroot is on a distinguished road
I would check grid independence again. When you check grid independence you are trying to determine if the solution that you obtained for your governing equations is sufficiently resolved by the grid that you used. Since the turbulence equations that you are solving are different, it can't be guaranteed that the same grid will do as good of a job resolving the solution. That being said, it is fairly likely that the same grid is fine since the solution of the turbulence equations influence the flow solution indirectly. However, it is good practice to always check.
cdegroot is offline   Reply With Quote
SSG Reynolds Stress Turbulent Source on Boundary st268 CFX 3 September 11, 2012 08:24
SSG Reynolds Turbulence Model Georges CFX 1 February 28, 2007 17:15
Convergence problems with SSG turbulence model Ram CFX 1 June 19, 2006 11:08
Questions about the Reynolds stress model empirer2002 Main CFD Forum 1 January 5, 2006 08:37
Reynolds stress Model Chimenti Martín Main CFD Forum 5 November 21, 2001 14:22
