Fortran 90 faster than C/C++
Old   March 4, 2006, 01:40
Default Re: Fortran 90 faster than C/C++
  #41
andy++
This kind of C code can be written only by a Fortran programmer. If you realy want to try and taste programming in C++ take a good programming course in C++.
Andy
Old   March 4, 2006, 06:53
  #42
Renato.
Sorry, as I said, C is to much for me... I'll keep programming in Fortran.
Old   March 4, 2006, 14:31
  #43
andy++
Even though I belong to a Fortran generation I have never written any programme in this language. Simply at the time I started my programming experience the only compiler available to me was Algol 60. Yes, yes I am so old and I think if I was able to learn C++ and become an expert everyone else can. The only problem is if you want to do it. If you are in a group of people programming in Fortran under version control you probably do not have any immediate need to switch to another language. But it is only temporary.
Andy
Old   March 6, 2006, 08:29
  #44
pivello
Well, we agree in something. I'm santista and I'll never be a flamenguista - even in Tokio!!!!!!!!
By the way, I've been working with fortran (77+90) since january. Do you know how to link c++ and fortran executables? I mean, one fortran executable calls a c++ one, or vice-versa?
Old   March 6, 2006, 09:31
  #45
Renato.
In order to link mixed-programmed routines you must firstly compile your routines with its respective compilers, after that you can link the compiled files (object files) with the main linker of your program, for example:
I use the Metis library (entirely written in C standard) with my Fortran 90 programs. After compiling Metis I have the libmetis.a file, thus I link this file with my executable program doing:
ifort -o MyProgram *.o libmetis.a
in Compaq Visual Fortran you must insert the libmetis.a file in the link tab, or set the enviroment variables INCLUDE and LIB of the compiler.
It's the easiest way. Some libraries and routines may require to write interfaces between the languages in order to define argument passing rules (but it's not so hard to do).
Cheers
Renato.
Old   March 6, 2006, 09:37
  #46
pivello
Thanks, that's what I was looking for.
Old   March 6, 2006, 10:21
  #47
Steve
And if you are porting to multiple platforms, bear in mind that you'll have more success if you use the C++ compiler as a front end to the linker. I.e. compile each file with the appropriate compiler, but link the lot together with a C++ compiler command on the objects.
Old   March 6, 2006, 13:26
Default a few good quotes
  #48
pc
This is always a heated debate. Perhaps we can close it off with a few good laughs about the "fun" of programming:
http://www.bellevuelinux.org/q_programming.html
Old   March 6, 2006, 14:49
  #49
pivello
I guess this will be the case, since we're going to use the solver written in fortran, and a GUI written in C++. So the GUI would call the solver at some moment, and the final user would just click a button for it.
Fortran Compiler-CFX12.1 Araz CFX 13 March 27, 2017 06:37
Intrinsic Procedure 'ISNAN' in GNU FORTRAN 77 hawk Main CFD Forum 1 April 12, 2005 23:13
visual fortran Monica Main CFD Forum 1 August 28, 2004 21:45
Fortran77 or Fortran 90 Swapnil CFX 2 November 26, 2002 16:16
Why Favoring Fortran over C/C++? Zi-Wei Chiou Main CFD Forum 35 September 26, 2001 10:34
