Multigrid method for SIMPLE Algorithm
Old   February 21, 2006, 18:11
Default Multigrid method for SIMPLE Algorithm
yang
hi, guys,
I am recently developing a 2d steady N-S model. I am using the SIMPLE Algorithm and it works well. I have problems on applying Multigrid method. I am not sure how to apply to the pressure correction equation. Does the pressure correction need to be restricted from finer to coarser grid?
Any suggestion will be greatly appreciated.
best,
yang
Old   February 23, 2006, 02:45
Default Re: Multigrid method for SIMPLE Algorithm
Ravi Kiran
Hi Yang
There is no necessity of a finer or coarse grid in case of applying multigrid method using SIMPLE
u can directly use the approach given in CFD for Engineers by Anderson Jr., and CFD for Heat Transfer and Fluid Mechanics by Tannehill, Anderson and Fletcher
which shows the grid notations for multigrid methods for SIMPLE algorithm
all the best Ravi
Old   February 23, 2006, 18:11
yang
Ravi,
I really appreciate your suggestion. I am going to read these two books, and they may help me out.
best,
Yang
explicit residual smoothing working with multigrid method zhanglei Main CFD Forum 0 August 30, 2010 13:20
Multigrid method Suresh kumar Main CFD Forum 1 April 24, 2006 21:07
Apply Multigrid method to SIMPLE Algorithm yang Main CFD Forum 1 February 25, 2006 12:28
SIMPLE ALGORITHM approach-Multigrid method Skumar Main CFD Forum 0 November 14, 2005 15:16
Unstructured Multigrid Method for Euler equations Jian Xia Main CFD Forum 8 December 20, 1999 13:31
