gamma-Retheta transition model
Old   October 23, 2012, 02:03
Default gamma-Retheta transition model
Mehdi Babamehdi
mb.pejvak is on a distinguished road
hi friends;
in gamma-Retheta transition model, iteration method should be used in empirical correlation for finding transition onset momentum thickness Reynold number. based on what Langtry mentioned in his thesis, it should converge after 10 iterations, but in my code, its error remains about 1.0e-3 and doesn't decrease after 1000 iterations. in this procedure two limitations should be considered in order to robustness of the formulas. after 3 iterations, this limitations don't satisfied and transition onset momentum thickness Reynold number become lower than 20 in grids near the flat plate. could anyone please tell me what exactly I should do if they pass the limitations?
and also is there any other iteration methods
which can be used for this purpose except the one that is mentioned in Langtry's thesis?
mb.pejvak is offline   Reply With Quote
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
Viscosity ratio in gamma-theta transition model based on k-w sst turb model Qiaol618 Main CFD Forum 8 June 9, 2012 07:43
SSt k-omega in gamma-Retetha transition model mb.pejvak Main CFD Forum 3 June 1, 2012 06:05
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
where to set CFX Transition Model? steven CFX 6 January 17, 2007 12:19
