How long an analysis for steady state drag?
Old   October 22, 2012, 12:35
Default How long an analysis for steady state drag?
ABF
Adam Falshaw
ABF is on a distinguished road
I'm modelling flow over a rigid body, with the aim of extracting drag and lift data. I'm curious as to whether there is a rule of thumb I can follow that will help me establish how long I ought to run the simulation for in order to be confident I'm getting the full picture?
An example analysis of flow over a steamlined body (torpedo shaped) was performed over 10s with the drag appearing to level-off after about 2-3s. However, my initial models of a sphere (as a learning, test-case) have shown the drag to appear to be level up to about 15seconds (Re about 1.5E6), before entering a complex sinusoidal pattern that I assume is due to the vortex shedding.
I'd like to be sure I'm not cutting off my analysis time too soon - I know the easiest option is simply to run the analysis for longer to see, but in the interest of processing time, this isn't a 'good' solution. Is there a rule of thumb I can follow?
Thanks
Adam
ABF is offline   Reply With Quote
Old   October 22, 2012, 12:48
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Thanks
Adam
Hello, to give some answer you should address the type of formulation you are using ... Are you using URANS or LES?
As general rule, you can control the total kinetic energy. When it is statistically steady (that is after the numerical transient is finished) you can take the samples to get a statistical average of the fields until your statistics are steady.
FMDenaro is offline   Reply With Quote
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
CFX analysis of a sphere - drag too low Rob Findlay CFX 6 March 26, 2007 11:11
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
Using turbulence model for steady state analysis Terry FLUENT 7 February 28, 2001 08:03
Unsteady State analysis of 2 bluff objects Desmond Hui FLUENT 8 September 1, 2000 09:56
