Analytic solution for 2D steady Euler equations |
October 15, 2012, 12:05 |
I'm trying to verifiy my CFD code for low Mach number flows with some analytical or manufactured solutions. The convection and/or diffusion equation for a scalar is fine and now I focus on the Navier Stokes equations: First, I want to check the non linear convection term, so I suppress the viscosity considering a perfect fluid and starting from the Green Taylor vorticies solution for Navier Stokes: I get this solution: which satisfies the steady Euler equations: I tried this solution with my CFD code setting boundary and initial conditions with the solution, the pressure is also imposed, not computed, with the solution. At each iteration, I solve the velocity components and then update the convective flux, solve velocity, update the convective flux, etc. I use finite volume, upwind or centered convective scheme. My problem: after some oscillations, the flow diverges and I don't understand why. Is the solution unstable ? Can't a solver for Navier Stokes solve an Euler problem ? Did or is anybody try this kind of problem ? Thanks. |
Delta form of Heat, Euler and NS equations | RameshK | Main CFD Forum | 3 | May 30, 2012 10:41 |
initialize flow field with steady state solution | holg | FLUENT | 0 | July 13, 2009 17:10 |
Euler equations | Brian | Main CFD Forum | 0 | September 8, 2008 06:19 |
Euler equations? | Jan Ramboer | Main CFD Forum | 2 | August 19, 1999 01:58 |
2d analytic Euler solutions? | niles pierce | Main CFD Forum | 1 | July 14, 1998 12:22 |
