aeroelasticity
Old   February 14, 2006, 21:38
Default aeroelasticity
lailong
Hi, I'm a Lailong, PhD student in the subject of Aeroelasticity. My major is nonlinear structural analysis using finite element method. In my research for solving a problem of limit cycle oscillation I should use a nonlinear computational fluid dynamics (CFD) to capture the bifurcations and hysteresis. My question is (in case I can not built up a CFD code recently), can I use any CFD software (after I have a steady state with stability convergence) to estimate the aerodynamic loads for each time step of the global time like a STEADY STATE CASE (which I means here that I will solve the problem not a transient but a steady state for a specific time step with deformed body or deformed the mesh)? By the way, I will use the spring analogy to deform the mesh. I will appreciate your reply. Thank you.
Old   February 15, 2006, 18:51
Default Re: aeroelasticity
Peter Attar
If you want a time accurate solution then you need to solve the unsteady fluid equations. Unless I am misunderstanding what you are trying to do....
Old   February 16, 2006, 01:48
lailong
Dear sir, What I mean in my mail that can I solve the CFD of my problem as a steady state case which means steady state for each time step for example for dt from 0.1 sec to 0.2 sec. Just like a pseudo-steady problem. I appreciate your reply. Thank you
Old   February 16, 2006, 05:44
Luca
The problem is unsteady of course. How you solve the equations is up to you. You can introduce psuedo-time to get the system to convergence in a fixed time step, and then advance in time once converged. Luca
Old   February 16, 2006, 06:34
lailong
Dear Sir, Thanks for all who replied me. I know that my information about CFD not too much because my major is nonlinear dynamic structure but I will appreciate your reply. Please, Mr. Luca can be more details about your reply.
Fundamental doubt about CFD and Aeroelasticity cfd_newbie Main CFD Forum 6 April 14, 2011 11:14
cfd/csd coupled for aeroelasticity adam_dyb FLUENT 0 December 24, 2008 13:41
Aeroelasticity Final Year Project CFD FSI options Andrew Ratcliffe Main CFD Forum 0 September 19, 2008 08:31
aeroelasticity zhuzhuhua Main CFD Forum 3 September 28, 2006 12:17
Aeroelasticity Texts AMR Main CFD Forum 1 August 8, 2001 09:07
