fortran compiler
Old   February 13, 2006, 03:47
Default fortran compiler
yfyap
hi there, i am currently using Compaq Visual Fortran Professional Edition 6.5.0. when i was compiling files with large arrays, the following messege pops up: total image size -2110959616 exceeds max (268435456) i guess the arrays that i have exceeded the limits of the compiler. is there any fortran compiler running on windows xp platform available to handle large arrays? thanks in advance. yfyap
Old   February 13, 2006, 06:10
Default Re: fortran compiler
Renato.
It has nothing to do with your Fortran compiler. It's due the amount of memory you have that isn't enough to hold your array. You could change your static array by allocatable but your lack of memory problem, probably, would return during run time. Sorry, buy more memory...
Cheers
Renato.
Old   February 13, 2006, 06:47
Renato.
By the way, what's the size of your array? Does it fit in your system memory?
If your problem comes up within a subroutine and you have enough memory to load your array this problem can be due a lack of stack memory reserved to subroutines.
Regards
Renato.
Old   February 13, 2006, 09:55
yfyap
hi, currently i have 1.2 Gigabyte of SDRAM. could u enlighten me the difference between system memory and stack memory? thank you very much and have a nice day! yfyap
Old   February 13, 2006, 09:57
ag
There is a link command that you can specify when you build to allocate more stack space. I can't remember what it is off the top of my head but it is buried somewhere in the documentation. I have the same compiler and allocating more stack space during linking should remedy your problem.
Old   February 13, 2006, 10:05
Curious
Yes Ag, you're right.
I guess the link command is /STACK:[value] (take a look in the Compaq's help using this keyword. It's all there.)
NOTE: this link command will only increase the memory available for stack use. If your system doesn't have enough memory to load your array, it'll not work.
Regards
Renato.
Old   February 13, 2006, 10:14
Renato.
So,
What's the size of your array?
suppose:
real*8 :: a(10000,10000) ! 10,000^2 * 8 bytes
you'll need, approximately:
10,000 * 10,000 * 8 = 8x10^8 bytes/1024 -> 7.81x10^5 Kb/1024 -> 7.629 x 10^2 Mb -> 0.74 Gb
have you done this estimative?
Regards
Renato.
Old   February 13, 2006, 10:31
yfyap
hi... thanks.. actually i did not do such an estimation for the memory required, i will check this. thank you very much! yfyap
Old   February 13, 2006, 10:34
yfyap
hi thanks!
Old   February 14, 2006, 12:22
Vinod Dhiman
Hi Yap
I hope you are from NTU. Well, I didn't read all the messages in thread, however, if there is a problem with matrix manipulation it's better to use dynamics allocation of array.
Vinod Dhiman
Old   February 14, 2006, 23:35
  #11
yfyap
yes! i will send u email on this. thanks! yit fatt
Old   February 19, 2006, 07:04
  #12
zonexo
actually i've this problem before, cos I just formed the matrix directly, ie a full matrix although it is very sparse. this will create a lot of wasted memory.
however, this problem was solved when i switch to using some sparse linear equations solver such as NSPCG. due to the new format of the matrix, there is considerable saving in memory. maybe you can try.
Old   February 19, 2006, 07:06
  #13
yfyap
hi thanks! this would be pretty useful to me.
Old   March 5, 2006, 11:19
  #14
m sohail arshad
i have had a similar problem using digital visual fortran. However, the max allowed allocatable stack size is 4294967295 and is independent of tha amount of RAM+virtual memory available in the system
Intel Fortran Compiler & Tutorial 17 Young CFX 1 March 30, 2011 02:39
Fortran Compiler and example Young CFX 1 March 22, 2011 23:26
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Fortran compiler Erik Siemens 2 November 28, 2008 21:05
Fortran compiler Arnab Siemens 5 September 14, 2004 04:59
