Recommendation of CFD package for simulating shock
Old   February 8, 2006, 08:27
Default Recommendation of CFD package for simulating shock
Nalleli
I will be working with shock tubes and want to compare my experimental results with CFD. For this a have to decide between three packages Star-CD, Fluent and CFX.
I need to know which one is better capturing the shocks.
Also the schemes available for compressible flow? What order accurate are they? I need at least a second order accurate scheme to capture the shocks.
Also, the stability that each package gives for this kind of simulations.
If anyone can give me pro's and con's for this kind of simulation, i would be really grateful.
regards, Nalleli
Old   February 9, 2006, 05:41
Default Re: Recommendation of CFD package for simulating s
diaw (Des Aubery)
Hi Nalleli,
A suggestion, if I may. Set up an example problem & ask all 3 suppliers to let you test their software - I would imagine for academic purposes.
Perhaps also ask them to predict how well your example problem would fair, & to perhaps help you set up a rough model. Often, these software houses have a worked example reasonably similar to your test case. Certainly enough for you to get a 'feel' which way to go.
I hope that helps.
diaw... (Des Aubery)
Extend Project 1.6-ext Binary Release for Mac OS X hjasak OpenFOAM Announcements from Other Sources 26 November 5, 2013 17:50
Future CFD Research Jas Main CFD Forum 10 March 30, 2013 13:26
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 21:30
Newbie needs CFD package for Turbine CURF Main CFD Forum 1 January 20, 2005 21:54
Which CFD package Jody Main CFD Forum 6 July 21, 2004 18:57
