November 19, 2012, 11:59 |
Periodic B.C
#21 | |
Rep Power: 15 |
November 19, 2012, 17:25 |
#22 |
Dear Kamu,
for several reasons i am not a Workbench user and i know nothing about the setting of the parameters for their external use in workbench. However, while in theory there should not be any difficulty in setting the pressure as a parameter, it happens that this variable is also very weird (it is an output for fixed mass flow rate cases, its monitoring is far from being straightforward, etc.)... so, there might be chances that it actually can't be used as parameter. |
November 20, 2012, 01:48 |
#23 | |
Rep Power: 15 |
Thanks alot, looks like i will have to get it manually from FLUENT. I have tried all possible post-processing options to see if there is anything that is related to it in vain. Otherwise thanks once again |
November 6, 2016, 08:36 |
#24 | |
Neda S. R. Nikou
Rep Power: 10 |
I have written a 3D Incompressible NS solver for solving a rectangular duct flow with periodic boundary conditions along the direction of flow (x). In my case of staggered grid, pressure was set based on finite volume method, for ux velocity i used finite volume along y, z and finite difference along x. it works for coarse grids and I have fully developed flow in domain but as I generate smaller grid size, residual of u, v, w and continuity oscillates and did not converge. I changed the relaxation factors to small values of 0.001, bu it did not work. Please, someone can help me... What is wrong? |
November 6, 2016, 09:02 |
#25 |
Filippo Maria Denaro
Rep Power: 73 |
I suggest to open a new post and provide full details fo your problem...however, I really don't understand the reason for using FV and FD in the same code.
periodic boundary condition in LES | martor | FLUENT | 3 | April 30, 2022 01:20 |
periodic boundary condition (translational) fluent 6.3 | haihek | FLUENT | 3 | January 22, 2014 05:10 |
Problem with a periodic boundary condition | chuck209 | CFX | 10 | May 9, 2012 17:15 |
External Radiation Boundary Condition for Grid Interface | CFD XUE | FLUENT | 0 | July 9, 2010 03:53 |
translational periodic boundary condition | Rola Afify | FLUENT | 2 | September 12, 2006 09:39 |
