Pressure around an airfoil in boundary-fitted coordinates |
September 28, 2012, 15:16 |
Mido
Rep Power: 15 |
I am trying to solve the viscous flow around an airfoil NACA 0012 using the vorticity streamfunction formulation in boundary-fitted coordinates , I have managed to find the velocity field everywhere but I can't seem to find a way to calculate the pressure field around the airfoil or at least on its surface to calculate the lift.
I have tried many things no thing seems to work. I started to doubt the velocity field,but the velocity field looks correct but I am not sure anymore. So I would appreciate it if anyone can get me a version of the pressure equation ( static or total ) in boundary fitted coordinates with the appropriate boundary conditions |
September 29, 2012, 12:27 |
Rep Power: 15 |
Hi, this answer might seem a little dumb but, can't you use Bernouilli equation to calculate pressure at every point?
Where and are the pressure and velocity modulus far upstream of the airfoil. This is valid for a incompressible flow (M<0.3). If your flow is compressible then you'll have to use the compressible version of the expression. I don't think the fact that you're using body-fitted coordinates changes anything, you just calculate p (or p-p_infinity) at every point of your domain. Was this answer helpful? Cheers, Michujo. |
September 30, 2012, 10:06 |
Mido
Rep Power: 15 |
Thanks but that's not what i am looking for
September 30, 2012, 11:21 |
Rep Power: 15 |
I don't know if you speak spanish but you might want to check this MSc. Thesis. The algorithm to compute pressure (along with the appropriate boundary conditions) in body-fitted coordinates is all explained.
http://e-archivo.uc3m.es/bitstream/1...ranjo_2009.pdf What she does essentially is to compute pressure at every point from the computed velocity field, regardless of the system of coordinates. Could you explain your question a little bit more in detail? Cheers, Michujo. |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 05:37 |
domain imbalance for enrgy equation | happy | CFX | 14 | September 6, 2012 01:54 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
Pressure Boundary Problems | Chris | Siemens | 2 | June 21, 2005 08:20 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
