MUSCL shock capturing on high aspect ratio meshes
Old   September 28, 2012, 15:21
Default MUSCL shock capturing on high aspect ratio meshes
Vijay Paul
vijay_paul is on a distinguished road
I have noticed that MUSCL generates oscillations (non-monotone behavior) behind oblique shocks if the mesh aspect ratio is high. The problem does not seem to occur near walls where structured meshes have very high aspect ratios. There are situations like backward facing step problem where downstream of the corner, mesh is highly anisotropic. If the shock is at an angle of 45 degrees and aspect ratio is 10, then shock will be 2-3 points wide in one direction and 20-30 points in the other. When the limiter tries to sharpen the shock front in latter direction, one ends with a stair case shaped shock and post shock oscillations. Any thoughts on this other than the simple suggestion of avoiding high anisotropy will be greatly appreciated.
vijay_paul is offline   Reply With Quote
Old   September 29, 2012, 01:16
Praveen. C
praveen is on a distinguished road
Your mesh is not able to resolve the shock. There is not much that can be done in this case, other than to adapt your mesh.
Using a higher order method like weno might help to some extent.
praveen is offline   Reply With Quote
mesh anisotropy, muscl, non-monotone oscillations
[ICEM] check aspect ratio camoesas ANSYS Meshing & Geometry 2 November 14, 2011 10:38
[ICEM] Mesh along axis for a wedge gives elements with extreme aspect ratio sangrampp ANSYS Meshing & Geometry 0 November 17, 2010 07:57
flow with high turbulent viscosity ratio Phillips Main CFD Forum 2 August 25, 2008 19:01
High aspect ratio in viscous sublayer? Marius Main CFD Forum 0 December 22, 2005 09:15
high aspect ratio elements Olivier CFX 5 April 3, 2003 07:55
