Error with higher order (2nd, GAMMA) upwind scheme
Old   September 24, 2012, 04:02
Default Error with higher order (2nd, GAMMA) upwind scheme
TWB
quarkz is on a distinguished road
I changed my solver from central to 1st order upwind scheme and it works fine when my cylinder is stationary.
When I tried using higher order schemes, such as 2nd order upwind or GAMMA, I get divergence and erroneous results.
I 've some questions when using higher order upwind scheme:
1. do i have to use higher resolution to ensure stability/accuracy?
2. are these schemes stable/accurate at low Re e.g. 100?
3. do i have to use smaller time step?
i tried to change the resolution and Re but there's still problems.
Hope someone can help. Tks.
quarkz is offline   Reply With Quote
First Order to Higher Order Blending Factor NormalVector FLUENT 4 November 13, 2023 08:06
applying 2nd order muscl scheme to 2D unstructured(triangle) grid dokeun Main CFD Forum 2 May 22, 2012 03:42
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
Higher order downwind scheme jelmer OpenFOAM Running, Solving & CFD 4 August 9, 2006 07:43
second order FD upwind scheme Heinz Wilkening Main CFD Forum 2 November 3, 1998 15:33
