values of k and e in bubbly and turbulent flows |
January 28, 2006, 03:19 |
i am new to multiphase simulations. i am having problems in estimating k & e values for bubbly flows through pipes particularly at inlet and outlet. are there any theoretical or empirical correlations available?? if so plz give me the reference. hope tht somebody bails me out of this!!
January 28, 2006, 04:02 |
Re: values of k and e in bubbly and turbulent flow
This is a 1 000 000 $ question !! How big are your bubbles compared to the calculation grid size? What kind of multiphase model are you using ?
January 28, 2006, 07:41 |
thanx for ur response. i am using eularian 2 fluid, and ASMM model for bubble column simulations. bubble diameter is 5 mm. the height of column is 1mtr with a dia of 19cm. the grid size i am using is 5 mm(radial)* 3.3mm(longitudinal). should i refine my grid size further??
Turbulent viscosity ration, Virtual mass | KP | FLUENT | 1 | February 20, 2011 15:17 |
Interaction in bubbly flow | summer | FLUENT | 1 | June 20, 2006 04:15 |
