fortran error for g77 compiler
Old   January 26, 2006, 22:27
Default fortran error for g77 compiler
vishwas
This queston is related to fortran coding I am running a fortran coode in Linux using g77 I get the following error when I compile the error. This error is related to the symbol (ampers and) & which I use as continuation of statement on next line. the error is read(11,*) (((x(i,j,k,n),i=1,ii(n)),j=1,jj(n)),k=1,kk(n)),^
& (((y(i,j,k,n),i=1,ii(n)),j=1,jj(n)),k=1,kk(n)), ^ Expression at (^) has incorrect data type or rank for its context (This is the error for first line) Statement at (^) begins with invalid token [info -f g77 M LEX] (This the error for second line) Can somebody tell me how to remove it
Thank you
Old   January 26, 2006, 22:42
Default Re: fortran error for g77 compiler
ag
Make sure the ampersand is in column 6.
Old   January 26, 2006, 22:44
Renato.
I've got lost when trying to understand your read statement. This problem can be due your implicit loops in the read statement (unbalanced parentheses or arrays with wrong rank). Why don't you try to rewrite this sentence with explicit loops? It would be easier to understand where is your problem...
Cheers
Renato
Old   January 26, 2006, 22:47
Renato.
Yeah Ag,
it's the first think Vishwas must check ;-)
Old   January 26, 2006, 23:20
vishwas
This queston is related to fortran coding. I am running a fortran code in Linux using g77. I get the following error when I compile the error. This error is related to the symbol (ampers and) & which I use as continuation of statement on next line. The ampersand is in column 6.
&(((y(i,j,k,n),i=1,ii(n)),j=1,jj(n)),k=1,kk(n)) ,
Expression at ^ has incorrect data type or rank for its context (This is the error for first line) Statement at (^) begins with invalid token [info -f g77 M LEX] (This the error for second line) Can somebody tell me how to remove it.
Thank you
Old   January 27, 2006, 06:47
andy
Assuming the third line you have not shown is something like:
& n=1,4)
you have missed a bracket at the beginning for the index n.
Old   January 27, 2006, 13:11
m. malik
Consider using explit loops: do i = 1, ii(n) do j = 1, jj(n) do k = 1, kk(n)
read (11,*) x(i,j,k,n), y(i,j, k,n) end do end do endo
Old   January 27, 2006, 13:29
m. malik
I hope it's obvious that in what I suggested in previous mail, there are seven (7) lines.
Old   January 29, 2006, 21:35
AnotherCFDUser
Malik's suggestion will lead to slightly different behaviour from the original code (which will read the data from a single line rather than from ii(n)*jj(n)*kk(n) separate lines). This could be fixed by using a format statement in the read.
Old   January 29, 2006, 21:44
AnotherCFDUser
As mentioned previously for FORTRAN 77 the code should read something like this:
123456 READ(11,*) 12345& (((x(i,j,k,n),i=1,ii(n)),j=1,jj(n)),k=1,kk(n)), 12345& (((y(i,j,k,n),i=1,ii(n)),j=1,jj(n)),k=1,kk(n)), 12345& (((z(i,j,k,n),i=1,ii(n)),j=1,jj(n)),k=1,kk(n))
where 12345 should be replaced with spaces.
You may also like to use a different character.
If the compiler is actually expecting f90 or f95 you may like to try:
READ(11,*) & (((x(i,j,k,n),i=1,ii(n)),j=1,jj(n)),k=1,kk(n)), & (((y(i,j,k,n),i=1,ii(n)),j=1,jj(n)),k=1,kk(n)), & (((z(i,j,k,n),i=1,ii(n)),j=1,jj(n)),k=1,kk(n))
If neither of these work perhaps you could post some more details of the code (which looks like a pretty standard PLOT3D reader).
Old   January 30, 2006, 18:16
  #11
vm
this works with my compiler:
read(11,*)((((x(i,j,k,n),i=1,ii(n)),j=1,jj(n)),k=1 ,kk(n)), & (((y(i,j,k,n),i=1,ii(n)),j=1,jj(n)),k=1,kk(n)),n=1 ,4)
& is in column 6
Intel Fortran Compiler & Tutorial 17 Young CFX 1 March 30, 2011 02:39
Fortran Compiler and example Young CFX 1 March 22, 2011 23:26
OF 1.6 | Ubuntu 9.10 (64bit) | GLIBCXX_3.4.11 not found piprus OpenFOAM Installation 22 February 25, 2010 14:43
Fortran compiler Erik Siemens 2 November 28, 2008 21:05
Fortran compiler Arnab Siemens 5 September 14, 2004 04:59
