mesh generation
Old   January 26, 2006, 01:46
Default mesh generation
srikanth
whenever we mesh a model, what is the procedure to take the mesh size. how can we say that the mesh that we generate is correct. do we need to follow any principle that must be satisfied.
thanks and waiting for ur reply.
srikanth
Old   January 26, 2006, 06:02
Default Re: mesh generation
Renato.
Meshing a model can be considered a kind of art of sculpture and depends of your experience besides the physics you'd like to solve with this model.
Most of the times your mesher (a good mesher) will produce "correct" meshes or an error (or warning) if it isn't possible to generate one. I guess your question is related to the quality of the mesh. Regarding mesh quality, your mesher (again) should be able to provide informations about some kind of mesh quality metrics (aspect ratio, edge ratio, minimal angle, Jacobian, etc...).
Cheers
Renato.
[ICEM] Generating Mesh for STL Car in Windtunnel Simulation tommymoose ANSYS Meshing & Geometry 48 April 15, 2013 05:24
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 04:52
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 12:45
mesh generation for in-cylinder fluent simulation hennas ANSYS Meshing & Geometry 2 May 31, 2011 16:08
General questions on grid-based computing Adrin Gharakhani Main CFD Forum 21 June 5, 2000 14:47
