Help with K-epsilon for 2D turbulence modelling
Old   September 7, 2012, 06:59
Default Help with K-epsilon for 2D turbulence modelling
Aditya Pandare
aditya.pandare is on a distinguished road
I'm simulating a flow though an volute casing.
I'm in the initial stages of showing grid independence.
the k-epsilon model was working fine until the no. of elements was around 2.5 lakhs.
in the 4 lakh element model im not getting a converged solution.
the residuals for continuity are not stable now.
I'm using the simple algorithm, with 2nd order upwind diff(used 1st order too; but same problem) 0.5 relaxation. its a single-phase flow.
Please suggest ways to converge this solution.
aditya.pandare is offline   Reply With Quote
Old   September 7, 2012, 08:46
Default Re : Help with K-epsilon for 2D turbulence modelling
Orkun Temel
Orkun is on a distinguished road
Hi aditya.pandare
It seems to me that there are two possibilities : numerical diffusion problem or wrong near-wall treatment.
For the case of near-wall treatment, as you probably know, when you fine you mesh near wall, you decrease the y_plus value of your closest cell to wall. If y_plus values had decreased under 5 or 6, you need to use enhanced wall functions to have solution for viscous sub-layer.
I would think that there would be numerical diffusion problem if you had not the same issue with a higher order discretization scheme.
Orkun
Orkun is offline   Reply With Quote
Old   September 7, 2012, 22:57
ztdep's Avatar
p ding
ztdep is on a distinguished road
Send a message via Yahoo to ztdep Send a message via Skype™ to ztdep
another possiblity:
change from single precesion to double precesion
ztdep is offline   Reply With Quote
Old   September 8, 2012, 03:13
Aditya Pandare
Hi orkun and ztdep! thnks for your reply!
I am getting a y+ value of around 3 to 4.
So I am running a simulation using enhanced wall treatment.
I will also run a double precision solution after this run!
another question, how do we find the value of velocity gradient at the wall?
since the velocity profile equations themselves are functions of friction velocity (which in turn is viscosity multiplied by velocity gradient at wall)
thanks again
Old   September 8, 2012, 07:06
Orkun Temel
You can use wall shear stress to calculate velocity gradient, or you may calculate it by a UDF.
Old   September 12, 2012, 06:10
Aditya Pandare
even After using the enhanced wall treatment, the solution isnt converging. I am checking convergence on the basis of area-weighted avg along a line.
Is it because i'm using an "outflow" boundary condition? would a pressure outlet be more suitable?
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 16 March 4, 2017 09:30
SimpleFoam k and epsilon bounded nedved OpenFOAM Running, Solving & CFD 1 November 25, 2008 21:21
a book for turbulence modelling Prapanj Main CFD Forum 1 August 21, 2007 06:13
Turbulence Modelling Richard Keays FLUENT 2 May 6, 2004 01:11
Multigrid Method in Turbulence Modelling Bipin Lokhande Main CFD Forum 1 November 11, 1998 20:20
