Formula for 2nd order upwind scheme for non-uniform grids?
Old   August 30, 2012, 04:57
Default Formula for 2nd order upwind scheme for non-uniform grids?
TWB
quarkz is on a distinguished road
I've seen the formula for 2nd order upwind scheme for uniform grids as:
phi_e = 1.5*phi_P - 0.5*phi_W for u_e > 0
phi_e = 1.5*phi_E - 0.5*phi_EE for u_e < 0
Is there a formula meant for non-uniform grids as well?
Thanks
quarkz is offline   Reply With Quote
Old   August 30, 2012, 05:57
michujo is on a distinguished road
Hi, you can try to derive it. Just take the Taylor expansions around the nodes E and EE, taking into account the different grid spacing \Delta x_i for node i.
The formulas you showed is a particular case where the grid spacing is constant. Under this assumption, the grid spacings appearing in numerator and denominator of your expressions when you solve for phi_e cancel out and \Delta x disappears from the equation. However, the different \Delta x_i will appear in the expression of phi_e if you consider grid non-uniformity.
I hope it helps.
Cheers,
Michujo.
michujo is offline   Reply With Quote
Old   August 30, 2012, 18:25
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by quarkz View Post
Thanks
Be careful that upwind schemes are usually first, third, fifth ... order accurate... the reason is to have a local truncation error that has a dissipative behaviour ... the above formulas are based on a linear extrapolation of the value, that is highly unstable in general.
I suggest to construct a second degree polynomial on non-uniform stencil in such a way that if u_e>0 then Phi_W,Phi_P, Phi_E are involved (the counterpart for u_e<0 involves Phi_P,Phi_E, Phi_EE).
This way the use of Phi_P ensures better stability properties
FMDenaro is offline   Reply With Quote
second order schemes marine OpenFOAM 67 April 11, 2022 19:19
Free jet simulation msarkar OpenFOAM Running, Solving & CFD 39 May 11, 2021 14:21
[swak4Foam] Air Conditioned room groovyBC Sebaj OpenFOAM Community Contributions 7 October 31, 2012 15:16
singularity? mihaipruna OpenFOAM Running, Solving & CFD 5 April 24, 2012 18:18
second order FD upwind scheme Heinz Wilkening Main CFD Forum 2 November 3, 1998 15:33
