How to measure eddy viscosity in a wind tunnel?
Old   August 21, 2012, 14:22
Default How to measure eddy viscosity in a wind tunnel?
lakeat's Avatar
Daniel WEI (老魏)
lakeat is on a distinguished road
Send a message via Skype™ to lakeat
Hi all,
Partly because it is related to turbulence modeling... But I still do not quite understand this.
Since eddy viscosity is not a physical property of fluid, and I want to know how "physical" this quantity implies?
When people say in external flow simulations, one of the most common practices is to set the inflow eddy viscosity ratio, beta=nu_T/nu. Many say beta should be around 0.1~0.2....
1. Does beta<1 mean the flow is laminar, or what? Then what 0.1~0.2 actually means?
2. Does it what actually means much dependent on the turb model we are using, or does this eddy viscosity ratio more close to have a physical meaning and hence independent of turbulence model?
3. Suppose I have a grid generated turbulence in a wind tunnel, which has a higher turbulence inflow, then without a priori turbulence model to use, or even perhaps out of the framework of eddy viscosity hypothesis, is it possible or how to calculate the turbulent viscosity then?
Many thanks in advance!
Daniel WEI
Boeing Research & Technology - China
Beijing, China
Email
lakeat is offline   Reply With Quote
Old   August 22, 2012, 04:01
Hamid Zoka
Hamidzoka is on a distinguished road
Dear Lakeat;
turbulent viscosity is related to turbulence modeling and based on some assumptions but it still has a physical meaning.
In Laminar flows diffusion in flow field is characterized by molecular viscosity.
But, turbulent flows in its nature consists random velocity fluctuations which intensifies diffusion in the flow. So, one method to account for this intensified diffusion is adding additional viscosity to the molecular one. this added viscosity is simply known as turbulent viscosity.
its definition ,however, depends on the model that you have selected
in k-epsilon turbulence models it is function of k and epsilon.
in spalart-Allmaras it is directly calculated from a transport equation.
higher order turbulence models does not use this concept explicitly and calculate this added diffusion in other ways.
Now, if you have turbulence intensity and turbulent integral length scale at the inlet, you can calculate k and epsilon and consequently the turbulent viscosity. But keep in mind that what you calculate is not a pure physical quantity like velocity or temperature. It is deeply dependent to the model you have used. in other words such a turbulent viscosity calculation can only assess your turbulence model and its underlying assumptions.
I hope it helps!
Regards
Hamidzoka is offline   Reply With Quote
Old   August 22, 2012, 12:08
lakeat's Avatar
Daniel WEI (老魏)
Excellent!
And I am very interested and grateful, if anyone can accurately or roughly give me some numbers of (1) k, (2) epsilon, and (3) eddy viscoity, that are typical in
* Wind tunnel
* Real ABL
That would be great. Thanks
Daniel WEI
Beijing, China
Email
Old   August 26, 2012, 05:15
truffaldino's Avatar
truffaldino is on a distinguished road
Originally Posted by lakeat View Post
Excellent!
* Wind tunnel
* Real ABL
To define turbulence intensity Tu in external flows I usually use the following equation from e^n transition theory
N_crit=-8.43-2.4*ln(Tu%/100%)
Situation N_crit:
sailplane 12-14
motorglider 11-13
clean wind tunnel 10-12
average wind tunnel 9
dirty wind tunnel 4-8
The turbulence length depends on typical size of the object in the flow. All the quantities of interest can be then derived using intensity and length. The relationships between these quantities can be found e.g; in the Fluent manal: "7.2.2 Determining the turbulence parameters"
http://hpce.iitm.ac.in/website/Manua...ug/node217.htm
truffaldino is offline   Reply With Quote
Old   August 27, 2012, 15:55
lakeat's Avatar
Daniel WEI (老魏)
Hmm, what did you mean by "e^n transition theory"? Could you share a link of it?
QUOTE: "The turbulence length depends on typical size of the object in the flow" ......
1. I think turbulence intensity and turbulence length scale are not linear correlated;
2. I think turbulence intensity is easy to measure, but length scale is more complex to measure;
3. My point is inflow turbulence length would change from case to case, strictly speaking, it has nothing to do with the object. Wouldn't you agree?
Daniel WEI
Beijing, China
Email
Wind Tunnel Turbulent Viscosity Ratio robinfisichella Main CFD Forum 0 March 14, 2010 09:40
setting value of turbulent intensity and turbulent viscosity ratio in wind tunnel nuimlabib Main CFD Forum 0 August 4, 2009 01:05
how to consider perforated wind tunnel wall in CFD simulation littlelz CFX 4 June 11, 2009 06:51
Virtual Wind Tunnel in FLUENT ND FLUENT 0 April 7, 2006 08:43
Wind Tunnel Website now online Mike Worthey Main CFD Forum 0 June 6, 2000 03:27
