How to implement swirling phenomenon to model FAN
Old   January 9, 2006, 00:40
Default How to implement swirling phenomenon to model FAN
OPticdesigner
HI I tried to use EFD.Lab to model a DC Axial Fan. How do I implement swirling phenomenon on the DC Axial fan?
Old   January 9, 2006, 04:37
Default Re: How to implement swirling phenomenon to model
Harry Fulmer
Buy Flotherm.
Old   January 9, 2006, 07:41
TITAN Algorithms, Staff
Dear OpticDesigner:
Swirl flows out of a fan can be implemented by setting tangential face velocity boundary conditions on the lea side of your fan object.
See the example I created at the following link: http://CFD.TITANAlgorithms.com
The fan model demonstrated on this page shows that a uniform swirl that can be created with just a small dedicated setup of control surfaces to create the swirl.
If you are interested in the model, I would be happy to provide it for you.
Kind Regards,
DSS www.TITANAlgorithms.com
Old   January 9, 2006, 08:16
Harry Fulmer
Wow, nice response!
The swirl is a function of the operating point of the fan, at high flow rates the proportion of swirl to axial velocity is reduced. This is all related to the fan efficiency curve.
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
implement of Spalart-Allmaras model K S Chang Main CFD Forum 1 August 21, 2010 17:59
FDS - how to implement your FORTRAN model???? ana Main CFD Forum 0 July 1, 2005 11:06
flow simulation across a small fan jane luo Main CFD Forum 15 April 12, 2004 18:49
Problem With User-Defined Fan Model Panel neihad FLUENT 0 November 25, 2001 18:21
