blade analysis of gas turbine
Old   January 8, 2006, 15:20
Default blade analysis of gas turbine
Fayyaz Husain
Could any one help me in starting with my project named FEM analysis of gas turbine blade and its optimization, if anayone help me by providing material about this topic... I really need help... Thanking in anticipation Fayyaz Husain
Old   March 3, 2010, 02:13
Hamid Zoka
Hamidzoka is on a distinguished road
Dear Fayyaz;
please clearly specify the type of FEM analysis. are you going to model stresses exerted to blade? if yes, you should firstly specify the forces acting on blade surfaces (namely centrifugal force and gas bending and torsional forces) by either a CFD analysis or easier analytic methods.
then, you should answer that what is going to be optimized in your analysis? in other words you should specify a objective function which determines the direction of an optimization analysis. a more detailed information about your project is required.
best regards
zoka
Hamidzoka is offline   Reply With Quote
CFD of gas Turbine blade Ali Raza Abid Main CFD Forum 9 February 18, 2012 06:04
force acting on gas turbine blade.... vvj Main CFD Forum 1 March 3, 2010 02:04
Setting up gas turbine blade geometry for meshing sherifkadry Main CFD Forum 0 June 1, 2009 17:28
internal cooling of gas turbine blade vinay FLUENT 0 October 20, 2008 16:20
FEA of gas turbine blade and disc sureee Main CFD Forum 3 March 15, 2006 05:59
