Whose programming is more difficult?DNS or LES?
Old   January 6, 2006, 10:09
Default Whose programming is more difficult?DNS or LES?
Adonis
I want to choose one requiring less effort.
Old   January 6, 2006, 10:11
Default Re: Whose programming is more difficult?DNS or LES
Guillaume
DNS, by definition.
Old   January 6, 2006, 10:40
tom
DNS is computationally expensive and therefore requires perhaps parallelisation and the handling of much data.LES is cheaper and probably can be carried out on a single fast PC; no parallelisation is then required.
Thus, developing and running a DNS code does not have to be easier than developing and running an LES code ...
Old   January 6, 2006, 11:20
Renato.
DNS, programming cheap (by definition as Guillaume said) but computationally very expensive
LES with classic Smagorisky, programming and computationally cheap (but with little accuracy)
Regards
Renato.
Old   January 6, 2006, 11:24
Default Rephrasing
Renato.
DNS: programming cheap (by definition as Guillaume said) but computationally very expensive
LES + classic Smagorisky and without any wall law: programming and computationally cheap (but with little accuracy)
Regards
Renato.
Old   January 6, 2006, 17:23
Guillaume
I understand the arguments about intensive computation for DNS with respect to LES but, as one does not use LES and DNS for the same cases (dimensions, turbulence intensity), in practice, one barely manages to resolve the inertial range of the turbulence spectrum without a fine mesh. Thus, LES is expensive as well.
LES basic and simple questions. dshawul Main CFD Forum 0 October 4, 2010 11:56
Turbulence dampening due to magnetic field in LES and RAS eelcovv OpenFOAM 0 June 8, 2010 12:35
Differences between a laminar code and a les one ben Main CFD Forum 9 February 17, 2005 00:40
LES on two phase flow Li Yang Main CFD Forum 0 May 12, 2004 09:10
Some Questions about LES. Bin Li Main CFD Forum 2 February 20, 2004 10:58
