August 3, 2012, 07:45 |
Exporting a mesh to Elmer CFD
Rep Power: 14 |
Hi, everybody.
I have a problem trying to export a mesh 2D from NGSolve to Elmer (CFD software). At the beginning I tried to open the geometry (step file) with Elmer to generate the mesh. However, it has problems to import 2D geometries and the mesh is generated with defects. Then, I tried with Ngsolve which could open the stp file and generate a good mesh, but now I can't export the file to one format to work with Elmer. Ngsolve doesn't export to Elmer format. I tried to export with the inp format of Abaqus, but the software crush. I tried to export into a msh format but Elmer fail to open it. Some suggestion? |
August 3, 2012, 23:57 |
Rep Power: 14 |
I going to ask in a different way.
Wish program do I need to made a 2D mesh to run in a CFD software? |
August 5, 2012, 23:31 |
Rep Power: 14 |
Thanks I will try it.
August 15, 2012, 08:40 |
Rami Ben-Zvi
Rep Power: 17 |
If you have access to ANSYS (at least older versions running APDL), there are Elmer Macros to directly export the mesh to ELMER.
August 16, 2012, 07:01 |
#6 | |
Rep Power: 14 |
thanks. |
mesh export, mesh format, ngsolve |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
[snappyHexMesh] Layers:problem with curvature | giulio.topazio | OpenFOAM Meshing & Mesh Conversion | 10 | August 22, 2012 10:03 |
Transport mesh from ICEM CFD, to Fluent, to Sysnoise | Wieland | FLUENT | 2 | April 15, 2012 07:28 |
[Netgen] boundary conditions and mesh exporting | vaina74 | OpenFOAM Meshing & Mesh Conversion | 2 | May 27, 2010 10:38 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 10:38 |
