Regarding pressure projection method for unsteady viscous compressible flow |
July 28, 2012, 07:15 |
#21 |
Do you have access to this?
Moureau, Berat, Pitsch (2007): An efficient semi-implicit compressible solver for large-eddy simulations. Journal of Computational Physics 226 There you will find useful references on the projection method for incompressible (costant and variable density) flows, plus you will see how the method is adapted to handle some acoustic features. However, i repeat it, it is very unlikely that the pressure-velocity coupling is causing you troubles in handling shocks. Indeed, i suggest you to actually use your current method (however the PISO from the Jasak's lecture notes is probably a better option than the SIMPLE) and look for something else causing your problems. Still, i realize from you posting the Jasak's notes, that the modifications needed by a segregated solver to handle compressible flows are new to you. So, i guess if they are also new to your senior... in that case there could really be a problem in your SIMPLE implementation. |
July 28, 2012, 07:55 |
#22 | |
Filippo Maria Denaro
Rep Power: 73 |
a failure in capturing schock with good resolution does not necessarily depends on the failure of the algorithm for compressible flows... maybe your spatial (and temporal) discretization is simply not good enough for problem with discontinuity |
pressure projection |
Compressible flow through a box at low pressure | nbulleid | OpenFOAM | 1 | January 20, 2011 06:15 |
Fixed grid methods for compressible viscous flow | liujmljm | Main CFD Forum | 1 | November 7, 2010 18:54 |
Using non-premixed model on compressible flow | Libing | FLUENT | 0 | November 10, 2005 19:39 |
pressure gradient term in low speed flow | Atit Koonsrisuk | Main CFD Forum | 2 | January 10, 2002 11:52 |
Method for Stokes flow with continuous pressure gradients? | Matthew Cordery | Main CFD Forum | 0 | August 31, 1998 18:58 |
