low-re models and heat transfer coefficient
Old   December 20, 2005, 12:12
Default low-re models and heat transfer coefficient
Massimo
Hi I'm working on oil distribution analysis. My flow model consists on small passages (diam. 4 mm) and I have to run a steady-state analysis with a commercial Code. Re number is about 12000. Flow enters from a circular tube (Inlet b.cond.) and exit from two ducts (2 Pressure b. cond) 1) I cannot use k-eps high-Re with wall function because I should use a 0.8-1 mm cell at wall in order to have correct y+ (30-100). 2) I tried to use both two layer models and k-eps low-Re/Hybrid Wall Function with a proper fine mesh at wall (15 layers with y+ less than 1). I do not know if the second way is correct or not. I can only say that by using the last two turbulence models 3) I found some strange values for heat transfer coefficients at wall, about 24000-30000 W/m2 K while proper values should be 4000-5000 W/m2 K
Could anyone tell me why I found so high heat trasfer coefficients and if low-Re models are correct or not for such calculations?
Thanks in advance.
Massimo
Old   December 21, 2005, 07:12
Default Re: low-re models and heat transfer coefficient
DenizeN
Have you calculate conjugate heat tranfer ?
Old   December 21, 2005, 10:47
Massimo
No, I have not. Nusselt number is a function of Re number and Pr number so it depends only on flow field and fluid properties (Cp,k, etc.). My calculation is isothermal. Heat transfer coefficient are required in order to be passed, later, to a stress analysis.
Old   December 21, 2005, 14:19
Denizen
It seems you are use Star-CD. The have two 1. Heat transfer coefficient calculated by empirical formule (Nu=f(Re,Pr)) 2. Hcoefficient calculated as qcell=alfacell/(Tbulk-Tcell)
First otimized fo some poblem(i do not know what)
Second work fine.
In conclusion you hawe wrong calculated heat transfer coefficient becouse you do not solfe heattransfer. Do not pay atention to this result about Hcoef, this do not means anything.
Old   December 22, 2005, 03:51
Massimo
Yes, I'm a Star-CD user. I'll try to evaluate Hcoe after having fixed wall temperature.
Thanks Massimo
Old   December 22, 2005, 03:57
DenizeN
Hcoef give probable value only if you solve conjugate hettransfer. You mast bulid real solid wall.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
Constant velocity of the material Sas CFX 15 July 13, 2010 09:56
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
