July 14, 2012, 04:04 |
Gerris or Openfoam?
HouKen
Rep Power: 15 |
Hi there!
I have been writing code to simulate two-phase flow in microchannel. After struggling for 2 years now I finally finished my thesis. To be honest writing code is hard for me and there remain a bunch of problems in my code. I start to consider using opensource code for several reasons: 1. I am not clever enough to study all the computational technique, coding tricks and test them by myself. It cost me too much time to debug my code which has almost nothing to do with physical phenomena. Opensource code is well coded by professional which is surely far more capable and reliable. 2. Opensource is "hackable". I can hack into any part of it if I want to customize or modify sth. Also user community will offer me useful information if I stuck. And now I have my question, which to use? My problem can be briefly described as below: 1. Laminar (maybe in the future I will consider for turbulence) 2. Two-phase (usually I focus on single bubble behavior, now I am using VOF in my code) 3. Surface tension (I applied CSF model but under microscale, "parasite current" is a problem) 4. Phase change (expansion of bubbles) 5. I want the code to be "hackable", which means friendly to people who want to change or modify something by themselves I am not familiar with openfoam or gerris. I know that Openfoam is very strong, and gerris is rather new and capable in dealing with surface tension. Which one will you guys recommend??? |
July 15, 2012, 04:51 |
ata kamyabi
Rep Power: 18 |
Hi
I recommend OpenFOAM because of its capabilities and supports in forums. |
July 16, 2012, 01:01 |
HouKen
Rep Power: 15 |
August 29, 2012, 18:04 |
Pharg Mandadapu
Rep Power: 15 |
Hi houkensjtu,
I'm interested in knowing why you think that Gerris seems more potential for the future? Does it have some feature that OpenFOAM doesn't have? Thanks. |
September 2, 2012, 10:36 |
#5 | |
Rep Power: 16 |
And I'm more confident in the growing of openfoam in the future compared to the one of Gerris. |
September 2, 2012, 10:41 |
#6 | |
Rep Power: 16 |
what you say is true, however what you gained in developping your own code is an invaluable experience in CFD. And even if you turn now for open source codes, you have definitely increased your understanding level of CFD and stuffs which matter. |
September 2, 2012, 22:27 |
#7 | |
HouKen
Rep Power: 15 |
Yes I do feel developing my own code increased my understanding in CFD. Also my professor suggest me to continue coding, but the issue here is, though it's possible to develop some low-level solver (following text book like Patankar or Versteeg), things become quite difficult when it comes to more complex model like phase-change. The reason why i think so, (actually i have never really code my own phase-change model) is that there will be no text book to follow. Most literature discussing about these models only focus on physical or mathematical properties, but not on coding tech. what will you suggest to do ? |
September 3, 2012, 05:58 |
Francesco Capuano
Rep Power: 16 |
Hi houkensjtu,
I've been making some basic comparisons for a simple two-phase problem between OpenFOAM and Gerris with the VOF approach. The results show that the current VOF implementation of OpenFOAM is quite inaccurate with respect to Gerris (see also http://www.uni-ulm.de/fileadmin/webs...s/CLSVOF.pdf); I can email you some pictures of my results, if you want. If your problems deal with simple, laminar flows, I would definitely go for Gerris. You should also consider that, in the current release, OpenFOAM does not support 2-D adaptive mesh refinement (although it does for 3-D), which, as you might know, is a fundamental feature for a good tracking of the interface. On the other hand, if you have to simulate flows of growing complexity (e.g. turbulence, phase change, etc.), then OpenFOAM is your best bet, especially if you manage to implement a coupled VOF / Level set method (see the above presentation). Regards, Francesco |
September 3, 2012, 10:40 |
#9 | |
Rep Power: 16 |
With time, they are improved with some additional new features (compressible, turbulence models, physical models , heat transfer, combustion, two-phase flow, numerical schemes, moving grids, etc...) according the will and the needs of each researcher. After sveral years (between 10 and 20 years) one obtains codes like OpenFoam, Star-CD, Fluent etc.... The material for undertsanding the models is all the litterature in CFD that you can find in scientific journals. The first think is to have a good and efficient Navier-Stokes solver in which you are very confident and which works fine. Then you start to add some new models... If you are interested in two-phase flows then start to really master VOF method, understand in details how it works, collect and read papers on this topic and when you feel ready start to code it. You can either find some open source codes like Sola VOF, Gerris,... wich are available on internet and then you can inspire from it. The other alternative is to use directly an open source code like Gerris , Openfoam which treat this problem. I have indeed heard that VOF implementation in Gerris was really good. I don't know about Openfoam. I have just seen that dambreak problem was treated as tutorial case in Openfoam. But I guess we can trust Francesco who have tested the both apparently. |
September 3, 2012, 11:43 |
#10 | |
Pharg Mandadapu
Rep Power: 15 |
September 3, 2012, 22:27 |
#11 | |
HouKen
Rep Power: 15 |
Yeah I noticed that Gerris supports adaptive mesh refinement which is really smart and that's one of the important reason I thought it's more potential than OpenFOAM. I'm really new to both Gerris and OpenFOAM, so I have no idea in how they work in phase-change model. Do you have any idea? One more thing I noticed is: I followed OpenFOAM tutorial's lid-driven cavity case, also I made a same mesh, same time step case in Gerris. Results are similar but Gerris was much much more slower than OpenFOAM. I am wondering why it happens. Finally my email add: houkensjtu@gmail.com, i am very interesting in comparison result between these two codes. THX! |
September 5, 2012, 22:16 |
#12 | |
HouKen
Rep Power: 15 |
September 6, 2012, 06:26 |
#13 | |
Francesco Capuano
Rep Power: 16 |
http://www.cfd-online.com/Forums/ope...hange-vof.html Nevertheless I know that OpenFOAM has some phase-change models which can be used in Lagrangian solvers (e.g. sprayFoam). Regarding the question of performances, in OpenFOAM almost all solvers use efficient segregated algorithms (SIMPLE, PISO, PIMPLE...), which in my experience work incredibly fast, especially for incompressible flows. I don't know much about the Gerris numerical algorithm (you can find all the details in Popinet's paper: http://gfs.sourceforge.net/wiki/index.php/Bibliography), but I know that it is second-order in space and time: have you checked that in OpenFOAM you also used such numerical schemes? I'll send you an email with the comparison as soon as I can. Regards, Francesco |
October 18, 2012, 22:37 |
#14 |
Alberto Passalacqua
Rep Power: 36 |
I would be interested in the comparison too :-)
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
October 19, 2012, 06:39 |
#15 |
Francesco Capuano
Rep Power: 16 |
The case setup is described in
A Orazzo, G Coppola, L de Luca, "Single-wave Kelvin-Helmoltz instability in nonparallel channel flow", Atomization and Sprays 21 (9), 775-785 and the article presents some results obtained with the codes GERRIS and SURFER. I have reproduced the test in OpenFOAM by using interFoam with a 2nd order accurate scheme in space and time on a fixed uniform mesh 800x400. I am attaching the solution after 8e-3 seconds, We = 1e5. t8e-3.png The elongated wave provided by OpenFOAM is clearly distorted and reproduced inaccurately with respect to the other two solvers. Such a problem is also shown in the link I gave some posts above. Regards, Francesco |
September 15, 2024, 03:24 |
#16 |
Geo
Kindly send the comparison results via mail
Mail: geojacobenjamin@gmail.com |
Issues with OpenFoam | sanjibdsharma | OpenFOAM | 0 | August 14, 2009 09:41 |
Critical errors during OpenFoam installation in OpenSuse 11.0 | amscosta | OpenFOAM | 5 | May 1, 2009 15:06 |
Problem installing OpenFOAM 1.5 installation on RHEL 4. | vwsj84 | OpenFOAM Installation | 4 | April 23, 2009 05:48 |
2009 OpenFOAM Summer School in Zagreb, Croatia | hjasak | OpenFOAM Announcements from Other Sources | 0 | March 27, 2009 13:08 |
64bitrhel5 OF installation instructions | mirko | OpenFOAM Installation | 2 | August 12, 2008 19:07 |
