about phase-field or second gradient theory
Old   December 13, 2005, 10:52
Default about phase-field or second gradient theory
Dusky.He
Recently, I study the papers about using the phase-field or second gradient theory to simulate two-phase flow. I am a little confused.
In short, does this method just add some special terms into N-S equation, and using the van der vaals equation of state to closing the equations?
any one can give me a hint?
thanks a lot
Old   December 13, 2005, 13:33
Default Re: about phase-field or second gradient theory
Angen
I know two-phase flows well but I have never heard about phase-field or second gradient theory. If you can give me a reference to a recent publication in this area, may be I can help. If you want to model compressible or variable density flows you need an equation of state that gives a relationship between density, temperature, and pressure. It can be van der Vaals equation or any other equation that is appropriate for your system.
Angen
Old   December 13, 2005, 15:57
John
You can ask Junseok Kim, he knows everything about it.
http://www.ima.umn.edu/~junkim/papers.htm
Also Jacquemin (?) in NASA microgravity program is the person to contact.
Old   December 14, 2005, 08:51
Dusky.He
The paper is: Jamet et la. The second gradient method for the dirext numerical simulation of liquid-vapor flows with phase change. Journal of computational physics 169, 624-651, 2001 I do not know the specific van der waals equation to close the equations in (6)-(8) stated in the paper.
thanks a lot
Old   December 14, 2005, 13:27
Angen
Thanks for a link. I am going to explore some of these ideas.
Angen
Old   December 14, 2005, 13:32
Angen
Thanks for a reference. I am going to get a copy of the paper and later I may be able to say more. Meantime you can find information on van der Vaals equation in any textbook in thermodynamics.
Angen
Old   December 15, 2005, 13:42
Angen
I have got the paper. It is interesting how some ideas that were quite popular in 40ies and 50ies see a renewed interest. At that time the concept of finite size of vapor-liquid interface was mainly used to caluculate surface tension based on the molecular properites. Here it is used as a way to determine the location of liquid vapor interface fully in a macroscopic contest. It is my feeling that although this idea may be useful for systems that are close to critical point it's usage is more problematic to the systems close to a triple point.
van der Vaals equation apears in the paper in reference to two different equtions. The first one is eq (1) in the paper expressing free energy in terms of bulk free energy plus a term dependent on pressure gradient. If you use eq. (4) you can recover a classical equation for free energy with surface tension. The second type is the famous van der Vaals equation of state (not written down in the paper) as depicted by isotherms in Fig. 3. However, authors are using mainly a modified equation of state due to the finite size of liquid-vapor interface.
If you would like to implement this method and have trouble to close equations the best would be to contact authors. There are e-mail addresses of the first two authors. If you decide to implement this method please let us know your opinion about it.
Angen
Old   December 15, 2005, 21:16
dusky.he
Your commend has been highly appreciated. I am quite new to this field. I do not want to implement this method totally, I just want to figure out how it could simulate the contact angle. maybe I can simulate the contact angle using the conventional cotinuum surface tension method.
In addition, do you have any commend on the simulation of the contact angle or contact line.
Thanks a lot.
Old   December 16, 2005, 13:21
Angen
The only way I determined contact angle in the past was by using a static balance of three surface tensions between solid surface, liquid and air. That is not necessarily valid for moving boundaries. I read a paper by Smolarkiewicz where he solve a problem of half drop on the surface spreading under the influence of gravity. I do not remember exact reference. It seems to me it was Journal of Computational Physics in late 90ies. For more information on contact angle you may try to search through Google with "Dynamic surface tension" or "Dynamic contact angle".
Angen
Old   December 17, 2005, 01:42
Dusky.He
Mr. Angen. Thanks for your comment. I am interested that paper just because it can simulate the contact angle. I will find more about it. thanks
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 05:49
TwoPhaseEulerFoam and Boundary conditions raagh77 OpenFOAM Running, Solving & CFD 99 February 6, 2018 19:31
phase field modeling of dendritic solidification shoney Main CFD Forum 0 June 14, 2011 13:52
How to set initial field in two phase case? (-eulerfoam) kjetil OpenFOAM Pre-Processing 3 July 14, 2009 05:52
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
