facing high courant number while running the case in OpenFOAM
Old   July 10, 2012, 07:43
Default facing high courant number while running the case in OpenFOAM
Nikhil
Nikhil Thakur is on a distinguished road
I am trying to simulate the incompressible flow of water through a cylinder.The cylinder at its base have many small circular openings.I have made the mesh of required geometry through gmesh.But while executing the file in OpenFoam the courant number is becoming high.My pressure and velocity fields are as follows:
| \\ / O peration | Version: 2.1.x |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0;
boundaryField
{ bottom
type fixedValue;
value uniform 1.4715;
top
type fixedValue;
value uniform 0;
wall1
type zeroGradient;
wall2
type zeroGradient;
wall3
type zeroGradient;
wall4
type zeroGradient;
U FILE:
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
bottom
type fixedValue;
value uniform (0 0 -.000004);
top
type fixedValue;
value uniform (0 0 0);
wall1
type zeroGradient;
wall2
type zeroGradient;
wall3
type zeroGradient;
wall4
type zeroGradient;
Nikhil Thakur is offline   Reply With Quote
Old   July 30, 2012, 05:23
Anne Gerdes
Anne Lincke is on a distinguished road
Hey,
you can control your Courant number automatically via a proper time step.
You just have to insert certain H-Files in your solver and add two parameters in your controlDict.
See this thread
http://www.cfd-online.com/Forums/ope...co-number.html
Kind Regards
Anne
Anne Lincke is offline   Reply With Quote
RMS Courant Number vs MAX Courant Number zoozoozoo Main CFD Forum 3 June 12, 2012 14:44
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 22:11
Very high courant number, time step continuity errors and bounding epsilon erncyc OpenFOAM Running, Solving & CFD 1 March 24, 2011 12:00
LES near wall model & courant number kasim CFX 5 March 16, 2008 19:23
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
