micro scale calculation problem
Old   July 3, 2012, 03:08
Default micro scale calculation problem
Guava Wang is on a distinguished road
Dear all,
Now my simulation model is that 10mm cyclinder with 20µm little radial clearance. I want to calculate the fluid is through the clearance condition.
-which turbulent model and wall function is suitable to use?
- how can i check mesh size in layer position with y plus in a reasonable range?
hope someone can help me. thank you in advance
Guava Wang is offline   Reply With Quote
Old   July 3, 2012, 06:56
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by Guava Wang View Post
Dear all,
I think that in microfluidic you have more relevant effects by viscosity and capillarity than worry about turbulence. I don't think you have a Re number sufficiently high to substain turbulent structures....
FMDenaro is offline   Reply With Quote
Old   July 3, 2012, 23:56
hi FMDenaro,
In the radial clearance, the velocity is 30m/s, which is turbulent structure. now my main issue is how to adapt the mesh size in reasonable range to assure the calculation accurate.
have a nice day
guava
Old   July 4, 2012, 04:44
hi FMDenaro,
have a nice day
guava
I am not an expert about microfluidic, I just see from some estimation, velocity and lenght of 20µm turn out to produce a small Re number. What about the axial velocity? I doubt that the energy production can balance the energy dissipation to substain turbulent structures and produce inertial range in the energy spectra... but I could be in error
Old   July 4, 2012, 05:32
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
What kind of fluid are you simulating? How high is the viscosity?
Estimating Re with an approximate value of air (1.5 e-5 m^2 s^-1) yields Re=40.
So your flow is definitely laminar (assuming the fluid you use doesn't have a lower viscosity than air) since the critical Re is in the range of 2300 for a circular pipe.
flotus1 is offline   Reply With Quote
Old   July 4, 2012, 22:02
hi flotus1,
viscosity is 2.24e-07 m^2 s^-1, and i have check the Re number, which is larger than 2300 in the clearance.
I can't upload the model as a picture, maybe the problem didn't give a clear description. my proposal for this case is to know the leakage with piston through the clearance 20 µm.
have a nice day
guava
Old   July 5, 2012, 02:26
flotus1's Avatar
Alex
Ok sorry for the detour, now lets get back to your initial question.
Since Re is still pretty low, the computational cost of fully resolving the boundary layer without a wall-function should not be too high.
Try to get the Y+ values below 1 to achieve this with a small growth factor (1.05-1.1) in wall-normal direction.
Thanks to the low Re again, the choice of the turbulence model will not be too important in this simulation. Any of the basic k-epsilon formulations should yield reasonable results.
Old   July 5, 2012, 03:27
I agree...what's more, your Re_tau is quite low such as a DNS is realizable
Old   July 13, 2012, 00:07
thanks. finally i adapt K-E model with scalable wall function, that can give good result.
Attempt to run rhoPisoTwinParcelFoam on micro scale jabecker OpenFOAM Running, Solving & CFD 3 April 13, 2021 09:52
How to find a good time scale strategy? StefanG CFX 19 June 8, 2012 09:41
[OpenFOAM] Paraview color scale problem Jdog ParaView 1 November 19, 2011 07:49
scale problem hughyang FLUENT 0 January 26, 2004 15:52
how to solve this problem in CFX5 calculation? cfxbeginer CFX 2 May 1, 2003 09:55
