Divergence while using RSM turbulence model
Old   June 16, 2012, 05:18
Default Divergence while using RSM turbulence model
Bharatt's Avatar
Bharat
Bharatt is on a distinguished road
Hello everyone,
i am running a simulation for different turbulence models for an airfoil. I am facing AMG divergence or sometimes FLOATING ERROR: OVERFLOW when i am shifting to RSM turbulence model.
the procedure i am following is achieving convergence in K-epsilon at first place and then shifting to RSM, the following parameters i used in initial(K-epsilon) stage.
Solver:- pressure based, Green-gauss node based
Viscous:- Standard K-epsilon
Boundary conditions(under turbulence):- K and epsilon
Scheme:- SIMPLE 1st order for 100 iterations then 2nd order(URF:- momentum reduced to 0.5 from 2nd order)
By about 4000 iterations convergence is achieved.
NOW, i go back to viscous:-
under solver-->viscous:- RSM, linear pressure strain etc and rest kept the same(parameters which i used for k-epsilon).
By about 100 iterations AMG divergence occurred
P.S:- please correct me if i am doing anything wrong!
-do i have to initialize it again?
thanks in advance
bharat
Bharatt is offline   Reply With Quote
Old   July 18, 2012, 19:23
Casey
meangreen is on a distinguished road
You don't have to initialize again, you can use the solution from k-epsilon to converge with RSM.
I wonder if you are running into issues with your boundary conditions. Are you checking your Y+ values at the walls?
meangreen is offline   Reply With Quote
Old   July 19, 2012, 06:16
Bharatt's Avatar
Bharat
Hey Casey,
Thanks for your comments. i'll keep that point in mind.
and yes i am checking for y+ values.
bharat
Old   July 23, 2012, 06:16
Rami Ben-Zvi
Rami is on a distinguished road
Smells like a Fluent simulation to me. If so - why don't you post it in the Fluent-dedicated forum?
Rami is offline   Reply With Quote
Modified k-e turbulence model UDF Travis Fluent UDF and Scheme Programming 7 November 11, 2018 21:21
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 04:20
turbulence model equation Andy Chen FLOW-3D 4 January 1, 2010 22:45
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
Turbulence model Herry Phoenics 1 May 29, 2003 14:19
