June 11, 2012, 18:44 |
SIMPLE Method
Satyajeet
Rep Power: 14 |
Hello everyone,
I have a question regarding SIMPLE method. Q. Can the SIMPLE method or its variants like SIMPLER etc., be used in codes based on explicit time stepping ? If yes, can you please refer a work, which reports this. Thank You |
June 11, 2012, 19:54 |
for unsteady problem, we use projection method or PISO
June 13, 2012, 17:47 |
Rep Power: 16 |
The question of satyajeet13 was not about steady or unsteady but explicit or implicit.
So I'm answering. Theoretically why not ? but I do not see the real interest to do such way ? For explicit time scheme you should better use the chorin algorithm which is in fact a kind of projection method. You have only two fractional steps instead of many iterations between to consecutive time step n and n+1 To be precise for Ztdep , simple can be used also for unsteady problems. |
October 2, 2012, 15:02 |
Satyajeet
Rep Power: 14 |
Thanks leflix for the reply.
SIMPLE family and Fractional Step Method | Geon-Hong | Main CFD Forum | 2 | April 5, 2010 19:05 |
SIMPLE method for inviscid flow | abcdef123 | Main CFD Forum | 0 | February 26, 2010 09:24 |
Apply Multigrid method to SIMPLE Algorithm | yang | Main CFD Forum | 1 | February 25, 2006 12:28 |
need help in fotran code for simple method | saritha | Main CFD Forum | 3 | April 30, 2004 13:55 |
SIMPLE method for compressible flow in pipe | Reza | Main CFD Forum | 0 | August 27, 2002 23:43 |
