Supersonic flow past cavity
Old   November 17, 2005, 09:31
Default Supersonic flow past cavity
Aditya
Can anyone suggest some papers for unsteady Supersonic flow past cavity.
Old   November 17, 2005, 12:52
Default Re: Supersonic flow past cavity
ganesh
Dear Aditya,
Please check out the paper by Rainald Lohner on "Adaptive Remeshing for compressible flow problems". I am not very sure if the title is exactly the same, but it almost is.
Regards,
Ganesh
Old   November 17, 2005, 13:40
Salvador
Check Hillier in JFM and articles within
Old   November 18, 2005, 11:49
Lionel Larchevêque
Up to M=3, subsonic and supersonic cavity flows are mostly similar. So if you are not focused on hypersonic flow, it could be of interest to also read about subsonic / transonic flows. If you are, see Hillier as suggested by Salvador.
First there is an old review with plenty of references interesting from both theoretical and historical points of view:
N. M. Komerath, K. K. Ahuja and F. W. Chambers, 1987. " Prediction and measurement of flows over cavities - a survey. " AIAA Paper 87-0166.
Here are some experimental and theoretical papers that could be useful :
H. H. Heller, S. E. Widnall, J. Jones et D. B. Bliss, 1973. " Water-table visualization of flow-induced pressure oscillations in shallow cavities for simulated supersonic flow condition. " Acoustical Society of America 86th meeting(Paper Z13). (very difficult to find)
H. H. Heller and D. B. Bliss, 1975. " The physical mechanism of flow-induced pressure fluctuations in cavities and concepts for their suppression. " AIAA Paper 75-491.
K. K. Ahuja and J. Mendoza, 1995. " Effects of cavity dimensions, boundary layer, and temperature on cavity noise with emphasis on benchmark data to validate computational aeroacoustic codes. " Contractor report no 4653, NASA, april 1995.
M. B. Tracy and E. B. Plentovich, 1997. " Cavity unsteady-pressure measurements at subsonic and transonic speeds. " Technical paper no 3669, NASA, december 1997.
E. J. Kerschen and A. Tumin, 2003. " A theoretical model of cavity acoustic resonances based on edge scattering process. " AIAA paper 2003-0175.
From a CFD point of view, in case of turbulent flows, RANS performs generally poorly on such configuration and supersonic LES are not so common. Nonetheless you may have a look at:
D. P. Rizzetta, 1988. " Numerical simulation of supersonic flow over a three dimensional cavity. " AIAA J. 26(7), pp. 799"807.
B. R. Smith, 2001. " Large eddy simulation of a supersonic cavity flow with an unstructured grid flow solver. " In: DNS / LES - progress and challenges : proceedings of the third AFOSR conference, C. Liu, L. Sakell and T. Beutner, ed., pp. 783"790. Greyden press, Columbus, Ohio.
D. P. Rizzetta and M. R. Visbal, 2003. " Large-eddy simulation of supersonic cavity flowfields including flow control. " AIAA J. 41(8), pp. 1452"1462.
Hope this helps,
Lionel
supersonic flow Steffen FLUENT 6 October 26, 2015 14:06
Unsteady simulation of flow past wheel Tom FLUENT 8 January 18, 2006 11:54
results for flow past flat plate normal to flow lisa Main CFD Forum 2 August 30, 2005 17:36
Skewed/inclined lid cavity flow quarkz Main CFD Forum 0 August 7, 2005 21:25
Inviscid Drag at subsonic, subcritical Mach # Axel Rohde Main CFD Forum 1 November 19, 2001 13:19
