Flow Through Shallow Channels (And I Mean Shallow!!)
Old   June 2, 2012, 13:29
Question Flow Through Shallow Channels (And I Mean Shallow!!)
Michael Petrarca
courtjester140 is on a distinguished road
I'm about to start a new project, taking a look at flow passing over a flat plate that has channels cut into the surface. The channels will be pretty shallow, say .00025 inches, and only about .015 inches wide, spanning the entire plate (which as far as I am concerned is infinity at this point).
I'm afraid of using typical theory here because of the small size of the channels. Is there a cutoff where microfluidics theory should be used? Is there an in-between macro and micro that I can use here?
My goal is to write a quick bit of code to analyize how the channels affect pressure and the boundary layer. This will be incompressible viscous flow.
As a bonus, i'd like to incorporate surface roughness in the channels, say ranging from 32-200 Ra. What tools do I have at my disposal to look at surface finish effects on flow from a purely analytical standpoint?
Thanks!
courtjester140 is offline   Reply With Quote
[ICEM] Flow channel meshing problems StefanG ANSYS Meshing & Geometry 19 May 15, 2012 07:44
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 21:28
properties of gas flow in channels romio FLUENT 1 June 28, 2007 15:30
Developing flow in channels benchmark Ted Main CFD Forum 0 July 24, 2003 16:59
fluid flow fundas ram Main CFD Forum 5 June 17, 2000 22:31
