Poly2Tri is ready for download from this weekend.
Old   November 13, 2005, 18:22
Default Poly2Tri is ready for download from this weekend.
Liang, Wu
Hi everyone,
Poly2Tri is ready for download from this long weekend. hope it's useful for someone who interested in this topic and can do real applications for you. please go to Poly2Tri's official website to download it and welcome to report bugs and comments and enjoy it!
Old   November 13, 2005, 18:26
Default Re: Poly2Tri is ready for download from this weeke
Liang, Wu
Sorry, this is the link: http://www.mema.ucl.ac.be/~wu/Poly2Tri/poly2tri.html or click here.
Old   November 14, 2005, 00:48
william
The efficiency seems not good.
Old   November 14, 2005, 00:49
william
Old   November 14, 2005, 05:01
Liang, Wu
Hi, william, Thanks for your comment. I have one question:which code did you compare with? Can you explain a little bit more? i'm waiting for details. Your info. is highly appreciated if you comment can improve the code.
Old   November 14, 2005, 07:40
andy
How does the performance of your code compare with Shewchucks widely used triangle code?
Old   November 14, 2005, 18:19
Liang, Wu
Hi, andy, you asked a very good question. About Jonathan's Triangle, it's well know that triangle is the best delaunay triangulation code open to public and it's famous for its refinement implementations. However, triangle is not comparable with Poly2Tri, since triangle generates Delanuany triangles directly, but poly2tri not, as mentaioned in poly2tri's website, polygon delauany triangualtion is not availbe for poly2tri's free public version . If you really won't compare poly2tri with triangle, you may download triangle and poly2tri and compare them with superior.bdm (included in poly2tri's distribution) and superior.poly from Jonathan's site, you will find poly2tri is around 4~5 time faster than triangle. However, it's unfair to triangle, since delaunay triangulation need additional flipping operations to generate delauany triangles. That's why on poly2tri's website, i didn't compare it with triangle.
Old   November 14, 2005, 22:32
william
I just run the code. Poly2Tri sample1.bdm It costs me a lot of time. I don't know why.
Old   November 15, 2005, 12:42
Liang, Wu
Frankly speaking, i have no idea about your probelem. So firstly, download the updated version(14/11/2005) and try it again. If you still have problem, please tell me your platform, your compiler and your command line options. Did you try other bdm files?
I also would like to ask someone else here who tried the code, did you have same problem as william mentioned? Thanks for your feedbacks and contributions.
