periodic BC in fluent & gambit
Old   July 15, 1999, 17:32
Default periodic BC in fluent & gambit
ray hong
Hi! there,
Could any one tell us how to use the rotating reference frame using fluent v5?
Sorry, we do not get any useful information from the online help of fluent.
Thank you very much!
Ray
Old   July 16, 1999, 01:28
Default Re: periodic BC in fluent & gambit
John C. Chien
(1). I learned how to use the earlier version of the codes by following their tutorial examples offered at the training session. I didn't attend the training session. (2). They have a couple of dozen such examples with step-by-step instructions and illustrations. The rotating reference frame is always confusing regardless of the code you use. You really have to follow the exact instructions. (3). Try to get a copy of such example first.
Old   July 16, 1999, 02:34
Tom
Hy, as John said: read the tutorials. There are some examples in the tutorial-manual 3: an axial-stage, a centrifugal-blower ... In general: you must define different fluid-zones. In the rotating fluid-zone, you select in the boundary-conditions-button Moving-reference-frame instead of stationary. So you have additional centrifugal and coriolis-forces in that fluid-zone.
tom
Old   July 21, 1999, 14:55
Phil Greenfield
One key point, the centerline of the rotating axis has to be aligned along the x-axis, if this helps.
CGNS import in fluent - periodic boundaries. Bjarne Børresen FLUENT 2 April 25, 2013 12:12
gambit with linux and fluent 12.1 kharnabnew FLUENT 0 October 5, 2010 10:33
SketchUp 3D model import to Gambit or Fluent Steve Johnson FLUENT 0 February 8, 2009 15:21
Gambit and Fluent Help Vincent Ryan FLUENT 2 January 11, 2009 08:34
Facing Few Problems in Fluent and Gambit Ravi Duggirala FLUENT 5 March 11, 2006 04:13
