free on line compressible flow book
Old   November 9, 2005, 21:56
Default free on line compressible flow book
genick bar-meir
I kindly would like to invite you and your students of gas dynamics to use my free software and book "fundamentals of compressible flow.'' The software and the book can be download at www.potto.org.
Genick Bar-Meir
This is the only book which describes how to calculate the different parameters for oblique shock analytically. Prove ``why the common believe in the continuous oblique shock'' is incorrect. This book is the only book which treats the flow realistically as bounded between upper limit of isothermal flow and the lower limit adiabatic (Fanno flow). This book also provides an extensive discussion on the evacuating and filling gaseous chambers from rigid to flexible. This book demonstrates that the chocking phenomenon doesn't occur only at the ``throat'' and at M=1 as traditionally believed and taught.
compressible flow calculation error using rhoSimpleFoam solver student4326 OpenFOAM Running, Solving & CFD 7 November 2, 2015 12:34
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 03:09
Compressible flow with free surface? mediode FLOW-3D 5 January 20, 2011 06:21
[Gmsh] Conversion Error nuovodna OpenFOAM Meshing & Mesh Conversion 14 October 1, 2010 12:07
1.7.x Environment Variables on Linux 10.04 rasma OpenFOAM Installation 9 July 30, 2010 05:43
