approximate factorisation
Old   November 2, 2005, 20:04
Default approximate factorisation
dist
can someone please tell me what approximate factorisation technique is?
thankyou.
Old   November 3, 2005, 05:52
Default Re: approximate factorisation
Tom
It's a way of splitting the matrix. For example for a full Lower/Upper factorization the matrix A is exactly factorized as A = LU while for an approximate factorization such as ILU you would have A = LU + N. Here N is the remainder and the basic idea behind approximate factorization is to make N as small as possible.
Old   November 3, 2005, 17:08
dist
ok, i suppose that makes sence.
but why do we use it? and how to we do about ensuring the n matrix is small?
thank you for your answer by the way.
Old   November 3, 2005, 17:48
ag
Consider a 2D system where the implicit difference equation is of the form
(I + A + B)*Q = RHS
The matrix I + A + B will in general be pentadiagonal and is more difficult to solve than the classic tridiagonal matrix. Approximate factorization makes the following substitution:
Let (I + A)*Q1 = RHS and solve for Q1, then
(I + B)*Q = Q1 to solve for the Q unknowns in the original equation. This factorization yields two systems which are each tridiagonal. The problem is the splitting error, which is found by multiplying out the two pieces:
(I + A)*Q1 = (I + A)*(I + B)*Q = RHS or
(I + A + B + AB)*Q = RHS
The quantity AB*Q is the splitting error, and will in general be a function of time step and cell size and the gradients of the flowfield. In two dimensions AF works reasonably well, but in 3D the splitting error will be O(dt**3) and can render an implicit scheme pointless unless measures are taken to deal with the splitting error. One such approach is to use the AF scheme within a global Newton iteration, such the the residual is driven to zero by the Newton and the AF is just used to get the approximate solution needed for the inner iteration.
Old   November 3, 2005, 18:12
ag
Sorry, that should be O(1/dt**3). It's been a long afternoon.
Old   November 4, 2005, 07:00
Tom
You use it when you can't perform the full inversion efficiently; i.e. the full LU factorization of a sparse matrix A is usually quite dense and so for a large matrix would take a vast amount of memory to store. With my example of ILU you assume that L and U only have non zero entries in the same locations as the original matrix A. Multiplying out LU you then equate the terms to those of A (the remaining terms are N).
The main reason for the use of approximate factorizations is that they can be used as postconditioners in other iterative solvers to help speed up convergence (LU is approximately equal to A but is relatively simple to invert).
energy equation and approximate factorization vahidmech Main CFD Forum 0 December 15, 2009 15:08
Why do we find the approximate solution? Meena Main CFD Forum 1 February 9, 2007 11:04
approximate factorisation sebed Main CFD Forum 0 October 19, 2005 19:18
Approximate Mixing due to Natural Convection Greg Perkins Main CFD Forum 0 February 12, 2003 19:43
ILU Factorisation rahul Main CFD Forum 3 June 6, 2002 00:32
