hydro power
Old   November 1, 2005, 22:57
Default hydro power
owen smith
id like to produce power out of a 6.5m wide stream trouble is there isnt much fall and can only dam it to 2m heigh could anyone advise me, if thats enough to turn a 100 kw turbine
Old   November 2, 2005, 20:34
Default Re: hydro power
Bak_Flow
Hi Owen,
interesting question, although you don't need CFD to do the calculation.
First law of thermodynamics says:
W_out = mdot_in(h + 1/2 V^2 + gz)_in - mdot_out(h + 1/2V^2 + gz)out
With: mdot_in = mdot_out h_in = h_out V_in = V_out Efficiency = 100%
W_out = mdot*gz
in metric units: W_out[W] = mdot[Kg/s]*9.81[m/s^2]*2[m] W_out[W] = mdot[Kg/s]*19.6[J/Kg]
So for 100[kW] you would need to pass 5000[Kg/s] through your turbine. That is about 5 m^3 of water/s. That seems like a lot for a 6.5[m] wide stream. Can you measure the current flow?
Check out the web there are some resources on backyard power-set ups and such that may have some useful info.
Good Luck,
Bak_Flow
Old   November 3, 2005, 01:14
owen smith
thanks BaK_Flow. understood 5 m3 could you explain calculation abreivations please.would daming river come into your calculations, more pressure less nozzle size to accomadate 5m3s. actualy river is 30m wide was only going to harness 6.5m, could channel more water if needed. at the moment average flow would be approx 10m3s.apprieciate your input. thanks owen.
PhD student project in CFD with OpenFOAM on hydro power generator cooling at Chalmers hani OpenFOAM 0 February 29, 2008 09:12
Hydro power turbine software moona mohammadi Main CFD Forum 0 May 25, 2006 11:24
Butterfly and spherical valves in hydro power moona mohammadi FLUENT 0 May 25, 2006 01:51
Butterfly and spherical valves in hydro power moona mohammadi Main CFD Forum 0 May 25, 2006 01:47
Hydro Power Plant in GAMBIT Mukkarum FLUENT 4 May 19, 2003 08:57
